Refer to Intel tech support case number 04521077.
Thanks for your help,
Stan
Before I say anything else, please edit and remove your email from your post. You don;t really need the SPAM that this will generate.
The available downloads for this graphics solution can be found here: https://downloadcenter.intel.com/search?keyword=intel+hd+graphics+2500.
I downloaded the driver from the site you recommended and it works fine. However, I also downloaded the same driver a couple days ago and it worked for less than a day so I'll keep my fingers crossed. Thanks for the help and the advice about my email.
Scott, how do I edit my previous post?
Nevermind, I found it. Sorry for the miscue.
What is the specific issue that you had with the driver when you tried it previously? I am not sure whether anything will be done in response to whatever you report regardless. My understanding is that work on this driver was terminated quite some time ago (at least a year; perhaps longer) and that the only thing being done is the address of security issues.
Compared to the faster HD Graphics 4000, the 2500 one features less Execution Units (6 versus 16) and only one texture sampler. Therefore, the performance is clearly worse and only suited for low demanding gaming. Intel states a 10 to 15% higher performance compared to the old Sandy Bridge based HD Graphics 2000.
Try using another driver for gaming.
Stan,
The 10.18.10.xxxx is the version number for the device driver, but Intel packages multiple device drivers in each installation package, so the version number for the package is going to differ. Luckily, you can take the "xxxx" portion of the version number - 5129, which is the build number - and use it to find the corresponding package. The full version number for the package is 15.33.50.5129. You can download it from here: https://downloadcenter.intel.com/download/29473/Intel-Graphics-Driver-for-Windows-15-33-.
Hope this helps,
