The "faulty" SSD is not visible under Windows tools, and not under usual disk management softs either (Acronis/Paragon/Easeus)
Intel SSD Toolbox /quick diagnostic says:ERROR:
"the selected ssd has no partition"
Considering this SSD is not visible and accessible (and I couldn't find an appropriate tool in Intel SSD toolbox to solve this issue and create a partition if that's of any help.
What would you suggest ?
Thanks in advance for your help (I would prefer to avoid command lines...)
Philippe
Hello pcant2,
Thank you for contacting Intel® Memory & Storage Support.
We noticed that you have an open case with our advanced technical support department that is related to the same issue, in which you were referred to your PC OEM (original equipment manufacturer) to get further support for your platform.
We encourage you to contact ASUS* to get additional assistance, We will continue to provide you with support in your original ticket.
Thank you for your patience and understanding.
Josh B.
A Contingent Worker at Intel
Hello pcant2,
Josh B.
