Items with no label
3339 Discussions
I need help with the camera regarding the installation. My camera is not recognized in the OBS if I would like to add as a greenscreen camera. Can someone help me. I have Windows 10 I use the Intel Realsense d415 camera
KKirc2
KKirc2
The drivers as well as the software Depth Quality Tool for Intel RealSense Cameras. I have already installed the plugin I have installed in OBS. Do I have to do a 3D scan or what do I have to do?
MartyG
The only green-screen solution supported for the 400 Series cameras that I know of is Mixcast, unfortunately.
https://mixcast.me/ditching-green-screen-mixcast-gdc-2018/?language=en_US
KKirc2
Du sprichst jetzt aber nicht Zufällig Deutsch ?
If you speak english can you help me please
KKirc2
The problem is that I want to play a game on OBS and either want to record or livestream. I have just downloaded and activated Mixcast (Free) and do not quite understand what I should do with the program.
KKirc2
If I add my camera as a video capture device then it will also be recognized. But I add it as an Intel Realsense 3D Camera GreenScreen Camera is nothing to see.
MartyG
I can talk to you in either German or English, whichever language is easier for you.
I recall that I have come across this problem with using the 'GreenScreen Camera' option several months ago with another user.
If you have a physical green-screen then there is a method for green-screening with OBS that is supposed to work with any camera and does not need special RealSense functions. Please go down to the heading on the page linked to below that is called 'How to set up your green screen in OBS Studio'.
https://www.windowscentral.com/how-use-green-screen-obs-and-xsplit?language=en_US.
I appreciate that this will not be helpful though if you do not have a green-screen wall. The user in that case I mentioned said "The whole reason for me buying the webcam was to avoid using a greenscreen, so that's not really an option".
I remembered that some years ago I wrote an article on using XSplit for green-screening a game avatar onto a video. I put the character in front of a surface with one color and extracted that color to make a cut-out of the character that could be overlaid onto the broadcast video in real-time. I managed to dig up the document and put it on a Google Drive download link.
https://drive.google.com/open?id=1uf2hxc-VGFUEoNToNQxxRs2kQPPG-pAj
If you want to give MixCast another try though, their website says "Streaming to your favorite platform can be handled by whichever screen-capture/streaming application you prefer. Some of our favorites are OBS Studio and GeForce Experience". So this suggests that using MixCast green-screening with OBS should be possible.
I found the instructions for the RealSense D415 / D435. Once the camera is configured according to their instructions, you hold down a Sample Background button for 10 to 20 seconds.
https://mixcast.me/docs/using-mixcast/?section=using-depth-sensing-cameras-5
KKirc2
Can you help me to set up the whole via Teamviewer? I'm running out of ideas so slowly.
MartyG
Support can only be provided through this forum, unfortunately. I have also heard cautionary tales of technicians who broke the operating systems on customers' computers through remote assistance connections like TeamViewer and got the blame for it.
KKirc2
What do I have to do to properly configure the camera? I have a program called Depth Quality Tool for Intel RealSense Cameras. But even then I can not get very far. My plan is not to use a green screen but via 3D scan to somehow cut the background. Is that possible somehow?
MartyG
There is a sample program for the RealSense camera called 'Align', where you can use a slider to remove the background and leave the foreground depth. It may not be of use to you though if you only want an RGB color image with the background removed.
If you have a recent version of the RealSense SDK installed, you can find a pre-built version of Align in this folder location on Windows:
C: > Program Files (x86) > Intel RealSense SDK 2.0 > tools > rs-align
KKirc2
And how can I put this into OBS now say how do I obs obs that I want to have the background? Or does not OBS support the Intel Realsense D415?
Eliza_D_Intel
Hello KKirc2, Please reach out to OBS support (https://obsproject.com/forum/) as they will be able to assist in resolving the issue you are currently facing. Thank you and best regards, Eliza
