Items with no label
3338 Discussions
I want to know the coordinates of a point on the depth map, and find the three-dimensional coordinates corresponding to the point on the generated point cloud.
tguan
I use:
     Cloud = pcl.load_XYZRGB('data/points/points7.ply')
     Visual = pcl.pcl_visualization.CloudViewing()
     visual.ShowColorCloud(cloud, b'cloud')
display point cloud, I want to know how to display the point cloud in real time after collecting data through sr300
I also want to know some tutorials on using pix on python, such as I want to do some painting on the point cloud, draw the line operation
tguan
I alread know the coordinates of a point on the depth map, i want to fin the three-dimensional coordinates corresponding to this point on the generated point cloud.
MartyG
A Python tutorial for generating a point cloud can be found at the link below:
https://github.com/dorodnic/binder_test/blob/master/pointcloud.ipynb
You can get the 3D coordinates from a point cloud with an instruction called rs2_deproject_pixel_to_point
https://github.com/IntelRealSense/librealsense/issues/1413
3D lines can be drawn on a point cloud using a type of function called a polyline. This can be done with the OpenCV software.
https://www.tutorialspoint.com/opencv/opencv_drawing_polylines.htm
tguan
捕获.PNGsorry,I want to display point clouds in real time, through video frames。
# Tell pointcloud object to map to this color fram
pc.map_to(color_frame) #problem:The color map does not match on the top, I don't know what this is for.
# Generate the pointcloud and texture mapping
cloud = pc.calculate(depth_frame)
points.export_to_ply("data/point/15.ply",color_frame)
#visualization,I only read the cloud data of this location to visualize, I don't know how to display the point cloud through real-time streaming.
cloud = pcl.load_XYZRGB('data/point/15.ply')
visual = pcl.pcl_visualization.CloudViewing()
flag = True
while flag:
flag != visual.WasStopped()
MartyG
Dorodnic the RealSense SDK Manager recommends using Open3D for real-time point cloud visualization.
http://www.open3d.org/docs/tutorial/Basic/pointcloud.html
An Open3D wrapper for RealSense SDK 2.0 to enable closer integration with Open3D is coming but I do not have a date for when it will be available.
tguan
Thank you very much for your help.
I have got the 3D coordinates on the point cloud. I want to draw the line on the point cloud.
you gave the information of the polyline , but it seems that I can't operate on the point cloud.
To pcl there is a PCLVisualizer, pcl::visualization::PCLVisualizer can draw lines on the point cloud and display the point cloud in real time. Do you have a tutorial on python?
MartyG
I recently suggested to another user that they draw the poyline using the OpenCV software with an instruction called cv2_polylines
If you wish to use Python, here are a couple of example tutorials for drawing a polyline:
https://pysource.com/2018/01/22/drawing-and-writing-on-images-opencv-3-4-with-python-3-tutorial-3/
http://opencvinpython.blogspot.com/2014/09/basic-drawing-examples-drawing-line-cv2.html
tguan
image = cv2.imread("red_panda.jpg")
cv2.polylines(image, [points], True, yellow, thickness=3)
this is operated on an image ,i am fingding​ a way to draw lines and circles on pointcloud and display the it in real time like a video
MartyG
I would recommend asking about it at the RealSense GitHub, as if the solution involves Open3D then it is beyond my current knowledge to provide an answer, unfortunately. You can post at the GitHub by visiting the link below and clicking the New Issue button.
tguan
