Items with no label
3338 Discussions
I want to make a simple Object tracking application with SR300 and SDK-R3
mniiz
I want to make a simple Object tracking application.
The Application roughly overview is following.
・preparatory step
・firstly User make a "3DScan.obj" by scanning target object with Scan3D.cs
・main step
・Application loads a "3DScan.obj" file made by prepartatory step.
・Application displays the streaming Image on the window and draw the circle on the target object
Question
・I don't know how to use *.obj file So Dose anyone have sample program like as described above?
※Configration
・windows10
・SR300
・SDK-R3
MartyG
It is possible to view .OBJ model files using the scripting language of your preference. For example, if you are using C++ then google for 'c++ obj viewer', or if using C# , search for 'C# obj viewer'. You should be able to integrate these scripts into your application.
There are also JavaScript versions available, though the old R2 and R3 SDKs have a potential security vulnerability in their web component that makes using web languages with your SDK applications inadvisable.
