Items with no label
3338 Discussions
Install image did not contain Euclid software
ELips
I inherited a Euclid from a former coworker and it was in less than working order.
I went through the process of reinstalling the factory image (twice), but it didn't install/copy the intel/euclid directory so I don't have any of the automations/web interface.
Is there something I missed? The install got stuck on "copying log files" both times and I rebooted so is it possible that there was a post-install script that didn't run?
MartyG
Can you confirm please that you are using the Euclid restore image from the link on this page:
ELips
Yes, that is the one I'm using.
MartyG
After you had installed the OS on Euclid, did you press the F5 key on your next boot-up to enter the BIOS and change the boot device back to internal storage instead of having it look on the USB stick for the OS?
ELips
I don't think I actually changed the boot order in the first place, I just chose to boot from the usb drive when I was installing. Either way, I know it was booting from the internal drive because the usb drive showed as a separate mounted drive. I've also booted it multiple times with the usb drive unplugged.
MartyG
I'll link this discussion to a member of the Euclid team - MeitavKleinfeld - who has posted on the forum in the past, to see if they can offer advice on your problem. Or a member of the Intel support team may also have a suggestion. Good luck!
ELips
ELips
My bad!
I just ran the installation a third time and this time actually waited for it to finish copying the installation logs (googling it suggested it was a Ubiquity hang) and it looks like I was right about it not running a post install script.
Everything is working again.
Thanks for your help!
MartyG
Awesome pawsome! I'm very glad you found a solution. Have a great day!
