Items with no label
3341 Discussions
Intel D435 can't read both streams at same time
JAcos2
I just received a Intel D435, and tried the Realsense Viewer, but it seems that it can't read both streams from camera at the same time, the color stream is running at a maximum of 1fps and later the app says "no frames received" and the stream stops.
If I stop the depth stream, RGB stream starts again, but I can't make them work at the same time. It doesn't matter the resolution set in both streams, so I don't think that is a bandwidth issue. Camera is connected using USB 3.0, using windows 10 build 16299.192, firmware 5.08.15.0
Hello iamjulianacosta,
Thank you for contacting Intel® RealSense™ Technology support.
In order to further assist you with your inquiry we would need the following basic information:
• A screenshot of Device Manager -> Imaging Devices.
• A screenshot of Device Manager -> Imaging Devices trying a different USB 3.0 port.
• A screenshot of the RealSense Viewer showing the error.
• Please update Windows 10 to the latest build:
https://support.microsoft.com/en-us/help/4073291/january-18-2018-kb4073291-os-build-16299-201.
• In order to discard any camera malfunction or any problem with the signal coming from the USB port of the PC, we need you to test your Intel® RealSense™ camera on another PC.
We will be looking forward to your reply sharing this information.
Josh B.
Intel Customer Support
NKruf
Check your frame buffer size under advanced for both streams. I've had that happen when it was under 4 on my desktop computer when streaming depth and color.
