Items with no label
3338 Discussions
Intel RealSense D435 Camera Qualtity Low
Ak22
Dear Sir,
We have purchased REALSENSE model D435 & D415.
ESSENTIALLY we have developed AR application for retail & fashion using KINECT V2 and as Microsoft has stopped producing we are looking at replacement for the same.
There is a strong requirement from the Industry and we are really stuck.
Attached please find picture from KINECT and also from REALSENSE.
We need your kind help and support to achieve the good quality and clarity like KINECT.
Also is their any other 3D depth sensing camera available in the market.
Thanks and waiting for your answer.
Please Find the below captured image from Intel RealSense D435
Please Find the below captured image from Kinect V2
MartyG
Kinect 2 and the RealSense 400 Series cameras do not use the same projection method, so it is difficult to make direct comparisons between them technologically. Kinect 2 uses 'Time of Flight' vision, whilst the D415 and D435 use Stereo imaging with left and right IR sensors. So results gained on Kinect 2 will not necessarily match images generated by the 400 Series.
You may find that you obtain a better image from the D415 model. Intel provides the following explanation for this: "Due to the wider FOV, the smaller baseline, and the smaller sensor resolution, the D435 has more depth noise (>2x) at any given range, compared to the D415. The D435 does however, benefit from having smaller minimum operation distance (minZ) at the same resolution. This means you can get closer to objects. For example, at 848x480 the D415 has a minZ of about 31cm, whereas the D435 has a minZ of about 19.5cm"
D415 also has the advantage of its RGB sensor being integrated into its camera module circuit board, whereas on the D435 the RGB sensor is attached separately.
There is an excellent guide for tuning the 400 Series cameras.
https://realsense.intel.com/wp-content/uploads/sites/63/BKM-For-Tuning-D435-and-D415-Cameras-Webinar_Rev3.pdf https://realsense.intel.com/wp-content/uploads/sites/63/BKM-For-Tuning-D435-and-D415-Cameras-Webinar_Rev3.pdf
Regarding alternative cameras, the most recent advice on this matter is "We do not discuss our competitors . Feel free to google depth cameras and take a look" .
MartyG
