Items with no label
3335 Discussions
Intel Realsense SR300 & Intel Joule 570x
TFrit2
Dear all,
is the Intel Realsense SR300 compatble with the Intel Joule 570x (USB compatibility)? I had struggle with the SR300 when I tried to connect it with my laptop, because of an older type of USB 3.0.
Does they work together?
Another question. I read several values of power supply for the Joule 570x (12V and 5.25V). Which one is correct? Which volt and amps is necessary?
Thanks a lot.
Timo Fritz
MartyG
The best RealSense camera choice for the Joule is the ZR300. The R200 may also work but is not officially supported to do so. The SR300 is not validated to work with the Joule, sadly, due to incompatible architectures. This has been stated to be the case by two Intel support staff members, Sergio and Pedro, in replies to other peoples' questions about SR300 compatibility.
Sergio explains the different power voltages in this post.
TFrit2
Thanks a lot!
Timo
