Items with no label
3338 Discussions
F200 Hands 3D viewer sample crashes when starting
lquad
Goodmorning,
I downloaded the SDK Hand Tracking module of the SDK.
When I have the camera connected (F200) and I try to open one of the F200 samples, the application crashes.
-the camera LED turn on
-the windows is created, in the bottom right corner appear the image sampeld by the camera.
Then, after 0.5-1 seconds, the application crashes.
Windows give me the possibility to click on a "Debug" button, if I do so, It open Visual studio.
the calling stack is:
I have windows 10 installed 64 bit;
I have a Intel64 Family 6 Model 58 Stepping 9 GeniuineIntel 3500 Mhz.
What Can I do? Any suggestion?
MartyG
I have never heard of a CPU being described in terms of family model and stepping numbers. However, using this information, it seems that your processor is an Intel Core i7-3770K. This would make it a 3rd generation "Ivy Bridge" architecture processor. The minimum specification for an F200 camera is a 4th generation "Haswell" architecture processor. If you use the camera with a processor generation earlier than 4th, you may be able to access basic RGB video (e.g webcam) and raw camera data functions, but not more advanced functions such as hand tracking.
lquad
Yes, sorry for that cpu description, was the result from the "systeminfo" command on the prompt.
Yes it is an i7-3770K CPU.
thanks for the help
