Items with no label
3335 Discussions
LIPS SDK for RealSense D400 Series,Version 1.0.4.0 Date 2018/12/19
SneakyLuke
Hi everyone, LIPS released new version SDK for RS D400 Series,
You could find at https://www.lips-hci.com/downloads/category
Version 1.0.4.0
2018/12/17
10.1MBytes
Model:Intel RealSense D400 Series
System:Windows 64,32 bit
Platform:OpenNI 1.5 and 2.2
Release Note:
• Fixed an issue when changing resolution will cause crash
• Fixed an issue to display serial number properly
• Fixed an issue where FPS couldn’t reach 30
• Enhanced RGB resolution to 1960 x 1080p @ 30 FPS
• Time bomb sets at 20 minutes
Supported Device:
• Intel® RealSense™ Camera D400-Series:
- Intel® RealSense™ Depth Cameras D415 and D435
Supported Interface:
• USB 3.0
Supported Resolution:
• 1920 x 1080p @ 15 or 30 FPS (RGB Only)
• 1280 x 720p @ 15 or 30 FPS (depth & RGB)
• 640 x 480p @ 15 or 30 FPS (depth & RGB) - Default
• 640 x 360p @ 15 or 30 FPS (depth & RGB)
• 320 x 240p @ 30 FPS (RGB Only)
Supported Platform:
• Windows 10 x86 & x64
• Linux x64
- Ubuntu 16.04 (Linux Kernels 4.8 ,4.10, and 4.13)
Supported Firmware:
• Intel D400-Series - Firmware Version: 5.10.6
• You may check & download the firmware at:
- https://realsense.intel.com/intel-realsense-downloads/#firmware
MartyG
Thanks very much for your continued support of RealSense in the LIPS SDK, Luke!
jb455
Valued Contributor II
Hi, thanks for posting this. I can't find any docs or other info on your website though - what can you actually do with this SDK?
SneakyLuke
If you installed OpenNI2.2, you could find the
Sample code at C:\Program Files\OpenNI2\Samples, especially SimpleViewer include point cloud viewer with fusion
Document or turotial at C:\Program Files\OpenNI2\Documentation
If you installed OpenNI1.5, you could find the
Sample code at C:\Program Files\OpenNI\Samples, NiViewer will show all detail
Document or turotial at C:\Program Files\OpenNI\Documentation
Or You could find more sample code at GitHub, https://github.com/lips-hci
Luke
jb455
Ok, so it's for getting streams from the camera, alternative to librealsense? Does it work with your 3D scanning or measurement tools?
