Items with no label
3338 Discussions
Librealsense error (pyrealsense) SR300
AGarr3
I can't import pyrealsense:
Python 2.7.6 (default, Oct 26 2016, 20:30:19)
[GCC 4.8.4] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import pyrealsense
/usr/local/lib/python2.7/dist-packages/pyrealsense/extlib.py:26: UserWarning: librealsense not found.
warnings.warn("librealsense not found.")
/usr/local/lib/python2.7/dist-packages/pyrealsense/extlib.py:33: UserWarning: rsutilwrapper not found.
warnings.warn("rsutilwrapper not found.")
My settings:
Ubuntu 14.04 LTS
Python 2.7.6
I installed https://github.com/IntelRealSense/librealsense# installation-guide librealsense and ran the examples. (without errors).
I installed dependencies: https://github.com/eliben/pycparser pycparser, http://cython.org/ Cython and http://www.numpy.org/ Numpy.
Finally I installed pyrealsense from source.
Thanks in advance
MartyG
Pyrealsense's documentation says that it has been tested with Ubuntu 16.04 LTS. I could find no mention of past compatibility with 14.04 LTS. I wonder if that is the cause of your problems.
AGarr3
EDIT:
I can run examples only from folder /Downloads/librealsense-master/build/examples not in installed folder /usr/local/bin
Error:
cpp-tutorial-1-depth: error while loading shared libraries: librealsense.so.1: cannot open shared object file: No such file or directory
