Items with no label
3338 Discussions
No IR image with R200 in ubuntu
RDohm
Hi there,
I'm using a HP Elitedesk 800 G2 mini desktop with a Intel® Core™ i7-6700T CPU @ 2.80GHz × 8 and a Intel® HD Graphics 530 (Skylake GT2) and after installation of the librealsense and realsens_camera packages I was not able to get any image at first so I changed the required version number of the librealsense in the package.xml of the realsens_camera package. After that I was able to get raw camera image but the IR still does not work. I can't get any information published on the IR topics and when I use dmesg I get 4 errors back:
ACPI Error: Needed [Buffer/String/Package], found [Integer] ffff89435397c510 (20170531/exresop-593)
ACPI Exception: AE_AML_OPERAND_TYPE, While resolving operands for [OpcodeName unavailable] (20170531/dswexec-461)
kvm: disabled by bios
uvcvideo: Failed to query (SET_CUR) UVC control 1 on unit 7: -32 (exp. 2).
I followed the installation process as it was described and after that I tried every trick that I could find on the internet but nothing works.
It would be nice if someone could help me!
MartyG
Your hardware specification is fine for the R200, so that shouldn't be the cause of the problem that you experienced.
"kvm: disabled by bios" is apparently an error generated by Ubuntu Linux, not by Librealsense. An Ask Ubuntu page explains the meaning of the error.
https://askubuntu.com/questions/303164/what-does-the-kvm-disabled-by-bios-message-during-the-boot-process-mean What does the "kvm disabled by bios" message during the boot process mean? - Ask Ubuntu
ACPI errors are computer BIOS-related errors related to configuring hardware components for the purposes of power management.
https://en.wikipedia.org/wiki/Advanced_Configuration_and_Power_Interface Advanced Configuration and Power Interface - Wikipedia
Although uvcv is mentioned often in Librealsense problems, it is apparently not specifically a Librealsense file, but rather is a Linux driver that webcams use.
Regarding the 'failed to query' issue: someone said in November 2016 that it may be caused by an operating system that needs to be updated, and that the update could be done with this instruction:
sudo apt-get update; sudo apt-get upgrade
RDohm
If I understand it right the kvm has nothing to do with the mallfunction of the realsense camera but de APCI could maybe be the problem but I cannot find a way to solve this error .
regarding the upgrade: I already upgraded several times
I am also working with the 4.13.0-041300rc4-lowlatency kernel.
MartyG
The most common kernel used successfully with Librealsense is 4.4.
