Items with no label
3340 Discussions
Question) How can I get 'depth' image as opencv?
mgum1
Hello, thank you for help.
There is two source code.
First one is basic example supplied by Intel, the second source which i modify is combined by opencv.
The problem is, I can't use "render". because of pipe.start(cfg)
i should use pipe.start(cfg) because 'cfg enable_stream--' function need that for showing color image.
but, because of this pipe.start(cfg), below
" depth_image.render(depth, { 0, 0, app.width() / 2, app.height() });"
sentence didn't work. (if i modify pipe.start(cfg) to pipe.start(), it did work.)
so, how can i active this render without delete pipe.start(cfg)?
or, is there any solution to make color image and depth image like first code on each window?
/////////////////////////////////////////////////// first code ////////////////////////////////////////////////////////
# include
# include "example.hpp"
int main(int argc, char * argv[]) try
window app(1280, 720, "RealSense Capture Example");
texture depth_image, color_image;
rs2::colorizer color_map;
rs2::pipeline pipe;
pipe.start();
while(app) // Application still alive?
rs2::frameset data = pipe.wait_for_frames();
rs2::frame depth = color_map(data.get_depth_frame());
rs2::frame color = data.get_color_frame();
color_image.render(color, { app.width() / 2, 0, app.width() / 2, app.height() });
return EXIT_SUCCESS;
/////////////////////////////////////////////////// second code ////////////////////////////////////////////////////////
# include
# include
using namespace std;
using namespace cv;
int main()
window app(1280, 720, "RealSense Capture");
rs2::pipeline pipe;
rs2::config cfg;
cfg.enable_stream(RS2_STREAM_COLOR, 640, 480, RS2_FORMAT_BGR8, 30);
cfg.enable_stream(RS2_STREAM_INFRARED, 640, 480, RS2_FORMAT_Y8, 30);
cfg.enable_stream(RS2_STREAM_DEPTH, 640, 480, RS2_FORMAT_Z16, 30);
pipe.start(cfg);
texture depth_image;
for (;;)
rs2::frameset frames = pipe.wait_for_frames();
rs2::frame color_frame = frames.get_color_frame();
rs2::frame depth_frame = frames.get_depth_frame();
depth_image.render(depth_frame, { 0 , 0 , app.width() / 2, app.height() });
// show the color image
Mat color(Size(640, 480), CV_8UC3, (void*)color_frame.get_data(), Mat::AUTO_STEP);
namedWindow("Display Image", WINDOW_AUTOSIZE);
imshow("Display Image", color);
// i want depth image by this code, but there's error.
/*Mat depth_show(Size(640, 480), CV_8UC1, (void*)depth_frame.get_data(), Mat::AUTO_STEP);
namedWindow("Display infrared", WINDOW_AUTOSIZE);
imshow("Display infrared", depth_show);*/
waitKey(10);
return 0;
Hello P_D_C,
This code achieves what you are trying to do:
rs2::pipeline pipe;
rs2::config cfg;
pipe.start(cfg);
// Declare depth colorizer for pretty visualization of depth data
rs2::colorizer color_map; //Added this, needed later
for (;;)
// rs2::frame depth_frame = frames.get_depth_frame();
rs2::frame depth_frame = color_map(frames.get_depth_frame()); // Find and colorize the depth data //Added color_map
Mat depth_show(Size(640, 480), CV_8UC3, (void*)depth_frame.get_data(), Mat::AUTO_STEP); //Changed CV_8UC1 -> CV_8UC3
waitKey(10);
return 0;
Jesus G.
Intel Customer Support
