Items with no label
3341 Discussões
R200 and unity not work
hothm
Novato
5.283 Visualizações
hi ,
i installed the last intel real sense sdk i test the sample with unity C:\Program Files (x86)\Intel\RSSDK\sample\core\RawStreams.unity
this sample work fine with F200 , but not work with R200, any help ?
12 Respostas
MartyG
Colaborador honorário III
2.565 Visualizações
When you say "the last" SDK, do you mean '2016 R2' version? Or do you mean the latest one, '2016 R3'? Support for the R200 ended after the 2016 R2 SDK, though the 2016 R3 SDK still supports the F200. So if you want to use an R200, you should be using the 2016 R2 SDK with it.
Edit: I re-read your message. you are using the Rawstreams Unity sample, yes? I believe that sample was introduced in the 2016 R3 SDK's Sample Browser application. So you are using the 2016 R3 SDK then, yes?
hothm
Novato
2.565 Visualizações
yes i use 2016 R3 SDK
hothm
Novato
2.565 Visualizações
but the R200 work good with others samples , only with UNITY not work
MartyG
2.565 Visualizações
As Rawstreams Unity first appeared in the 2016 R3 SDK, it was likely not designed to work with R200, because if R3 does not support the R200 then there would be no point in specially writing a R200-compatible sample program.
hothm
Novato
2.565 Visualizações
that mean can't use R200 with unity in R3 ?
hothm
Novato
2.565 Visualizações
please help me to find the best vesrion for sdk and unity to use R200 , i want this versions not really old
MartyG
2.565 Visualizações
The best version for R200 is 2016 R2, which you can download from this direct link that launches immediately.
http://registrationcenter-download.intel.com/akdlm/irc_nas/vcp/9078/intel_rs_sdk_offline_package_10.0.26.0396.exe
hothm
Novato
2.565 Visualizações
thanks a lot , and unity 5.4.3 is good ?
MartyG
2.565 Visualizações
I am currently using the Unity 5.6 beta without problems, and also used 5,4 in the past without any trouble with the camera.
hothm
Novato
2.565 Visualizações
great thanks , i will install SDK R2 , maybe i will have another questions
MartyG
2.565 Visualizações
Please feel free to come back to ask as many questions as you need to. Good luck!
hothm
Novato
2.565 Visualizações
thanksss
Responder
