Items with no label
3341 Discussions
R200 config ui on windows 10 platform
WHsia2
Hello Gentleman,
Is there any SDK could be used to configure R200 hardware parameters (contract, brightness, ... ) on windows 10 platform?
Because we want to use the sensor (R200) at the outdoor environment, so we want to configure these parameters to fitting the sunlight environment.
Walker
MartyG
It sounds like your needs would be served by RealSense developer Samontab's laser configuration tool. It was originally designed for the F200 desktop camera, though Samontab thought it ought to work for R200 too (he didn't have an R200 so couldn't test it). Other developers reported that it worked for the new SR-300 camera if it was run using the Windows 8 compatibility mode.
https://software.intel.com/en-us/forums/realsense/topic/537872 Utility for changing laser camera parameters (IVCAM v0.5)
Edit: here's the download link so you don't have to go searching through the long string of comments for it.
http://www.samontab.com/web/files/ivcam.zip http://www.samontab.com/web/files/ivcam.zip
WHsia2
Thanks for your information, it seem like a good configuration tool.
But i got "IVcam.exe stopped working" error when i run the tool at windows 10 even i using the Windows 8 compatibility mode.
Could you have any other advice? Thanks again.
My laptop environment:
OS: wondows 10 (10240)
intel DCM version: 2.1.27.2853
Device FW version: 1.0.72.10
MartyG
On a different posting, Samontab advised disabling the R200's IR emitter with scripting, since over-exposure of light could reduce the R200's capture quality.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?setdsenableemitter_device_pxccapture.html Intel® RealSense™ SDK 2016 R2 Documentation
Someone tried following this advice to disable the emitter and said that it improved their capture in strong sunlight.
In regard to an alternate configuration tool, on the open-source RealSense SDK called Librealsense there is a tool called cpp-config-ui.
https://github.com/IntelRealSense/librealsense/tree/master/librealsense.vc12/cpp-config-ui librealsense/librealsense.vc12/cpp-config-ui at master · IntelRealSense/librealsense · GitHub
WHsia2
Dear MartyG
Thanks for your help,
I could use the cpp-config-ui to fine tune the parameter,
I will also try to disable the R200's IR emitter for testing, thanks again.
MartyG
Glad I could be of help. Good luck!
