Items with no label
3340 Discussions
R200 width angle
IMyas
Sorry if this question was previously discussed. I haven't found anywhere information about width angle of the camera r200, but extremely need it. If you know, could you help me please? Probably it's between 60 and 120, but what is exact?
Thank you
Hi Vanyagvozd,
Thank you for contacting us. I believe ypu're referring to the field of view parameters. You can check look for this information in the specifications section of this document http://www.google.com/url?q=http://reconstructme.net/qa_faqs/intel-realsense-r200-review/&sa=D&sntz=1&usg=AFQjCNEBzBJheLVfW7totqNEgdSfHCJeKw http://reconstructme.net/qa_faqs/intel-realsense-r200-review/.
Let us know if this is what you were looking for.
-Sergio
IMyas
Thank you for your answer! If it's possible, could you clarify what is angle width if the purpose of camera is calculation distance between camera and person?
Hi Vanyagvozd
We'll investigate further and contact you soon.
-Sergio
Hi Vanyagvozd
Thank you for your patience.
The angle width doesn't vary depending on the distance. The camera's field of view angles are the ones found in the aforementioned link.
Field of view (D x V x H) (color) is 77° x 43° x 70° (Cone)
Field of view (D x V x H) (depth / IR) is 70° x 46° x 59° (Cone)
D: Diagonal
V: Vertical
H: Horizontal
-Sergio
IMyas
Thank you very much! Your answer was really helpful for me.
No problem Vanyagvozd! It's great to hear your issue is solved. Feel free to ask in the community again if help is needed.
Sergio
