Items with no label
Avisos
3338 Discusiones
RGB Intrinsics not changing after calibration
MPurs1
Principiante
1.770 Vistas
We are performing repeated calibration of a Real Sense D415 to check how camera intrinsics vary. Using a target and the supplied Calibration Tools, we found some variation in the Depth intrinsics parameters, but none in RGB. It seems that despite following the Calibration software's dedicated RGB calibration step, no change is made to the factory intrinsics.
Is this to be expected? How come?
Thanks!
Camera ModelD415Firmware Version5.9.14Operating System & VersionWin 10PlatformPC
0 kudos
1 Solución
Empleados
686 Vistas
Hi mso-michael,
The calibration software is reporting the intrinsics for the 1280 x 800 resolution for the Y16 (unrectified)
format.
The left and right infrared images are rectified by default:
https://github.com/IntelRealSense/librealsense/wiki/Projection-in-RealSense-SDK-2.0# d400-series.
Alexandra
Ver la solución en mensaje original publicado
2 Respuestas
Empleados
687 Vistas
Hi mso-michael,
format.
Alexandra
Empleados
686 Vistas
Hi mso-michael,
Was my answer helpful?
Do you have further questions?
Alexandra
Responder
