Items with no label
3339 Discussions
ROS : How to change the publishing rate of image
ACast36
The rate at which the the topic /camera/depth/aligned_depth_to_color/image_raw , is published is about 29 Fps.
I want to reduce this rate to publish only twice per second.
How could I make this change ?
MartyG
My ROS coding knowledge is not very deep. My research indicates though that a node called Throttle is a way to limit publishing speed at roslaunch.
https://answers.ros.org/question/40304/creating-a-throttle-node/
MartyG
Would ros :: Rate meet your needs, please?
http://docs.ros.org/diamondback/api/rostime/html/classros_1_1Rate.html
MartyG
ACast36
Thanks for your response @MartyG​ .
Are you saying that I should subscribe to the "/camera/depth/aligned_depth_to_color/image_raw" topic (which is published after launching the rs_camera.launch file) from my own node and then republish it at a different rate ? Yes that could be a solution.
But wouldn't it be more efficient to change the rate at which the topics are published, from the scripts that are launched when the rs_camera launch file is launched in the first place?
I am not sure though where in the scripts included in that launch file is the publishing rate set .
MartyG
ACast36
@MartyG​  throttling worked perfect. It was so simple too !
Thanks so much !
MartyG
You are welcome. I'm very glad I could help. :)
