Items with no label
3341 Discussions
RealSense D415 is sometimes recognized as USB2.x device on Windows 10 Pro.
shige
Hi all,
Our use case is,
  • Windows 10 Pro (latest updated)
  • RealSense D415 (fw: 05.11.15.00 / SDK: 2.29.0 )
  • Use long USB3.0 comptibility repeater cable (3.0m)
  • Intel NUC NUC8i5BEH
Following URL seems to be described same as this issue,
https://www.intel.com/content/www/us/en/support/articles/000027498/emerging-technologies/intel-realsense-technology.html
It's mentioned about workaround only.
I would like to know, How to make RealSense sure to be recognized as USB3.0 device ?
With Best Regards,
shige
MartyG
Assuming that your USB repeater cable is of a high quality (industrial grade) and not too long (20 meters has been suggested as a maximum for a repeater cable) then the camera may sometimes be mis-identified as USB2 if the USB connector is inserted slowly instead of with a quick and firm insertion motion.
shige
I use RealSense D415 after recognized as USB3.0, and only restart PC.
So, I think it's not caused by the way to insertion.
But, unfortunately, I use no industrial grade repeater.
Do you know any industrial 3.0m repeater as USB3.0 ?
MartyG
My personal recommendation for a supplier of industrial grade cables for RealSense 400 Series cameras is Newnex. This recommendation is primarily based on their demonstration in video evidence that it works, and the recommendations of RealSense users who have used Newnex cables.
For longer ranges (100 meters +) Newnex also offer a fiber optic solution.
https://www.newnex.com/realsense-3d-camera-connectivity.php
https://www.youtube.com/watch?v=GLQgR1jT04M
An alternative method to repeaters for long-range use is ethernet networking, such as the 'EtherSense' project created by an Intel RealSense employee.
https://github.com/krejov100/EtherSense
shige
I try it. Thank you.
