Items with no label
3338 Discussions
RealSense SDK 2.0 Build 2.11.0 Released
MartyG
Hi everyone,
A new 'Latest Release' stable build of the Realsense SDK 2.0 (version 2.11.0) has been released and is available for download here:
https://github.com/IntelRealSense/librealsense/releases/tag/v2.11.0 Release Intel® RealSense™ SDK 2.0 (Build 2.11.0) · IntelRealSense/librealsense · GitHub
Functions added to the API include:
- rs2_create_processing_block_fptr - Allows to create custom processing blocks using C-bindings (C, LabView, .NET)
- rs2_start_processing_fptr - Allows to start a processing block with a callback
- rs2_config_enable_device_from_file_repeat_option - Allows to configure pipeline to play from recording while controlling playback-repeat behavior
- rs2_create_hole_filling_filter_block - Hole-Filling filter supports three modes of operation:
New features are:
- Playback Repeat control
- Exposing Multipin UVC device via pybackend
- Post-Processing via Python API
- SSE optimization of PointCloud processing block
- Adding a dedicated Hole-Filling processing block)
- Adding USB3.2 descriptor support
- Notify user when new firmware is available
- Adding processing APIs to the .NET wrapper
- New camera info attribute: RS2_CAMERA_INFO_RECOMMENDED_FIRMWARE_VERSION, tracking the firmware recommended for D400 devices
Notable bug fixes include:
- Fixing Z-accuracy metric calculation in the Depth Quality Tool
- Compilation on ARM
- And more
The full release notes, including other bug fixes and a list of Known Issues, can be found here:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes Release Notes · IntelRealSense/librealsense Wiki · GitHub
