Items with no label
3340 Discussions
RealSense SDK version 2.19.0 now available (T265 support, Android unrooted support, C# & Unity additions and much more)
MartyG
Hi everyone,
Version 2.19.0 of RealSense SDK 2.0 is now available from the link below.
https://github.com/IntelRealSense/librealsense/releases/
API CHANGES
There are extensive additions to the API, too many to list here. They cover the areas of:
Processing blocks / filters
Options API
Device management
T265-specific APIs
Notice is also given that the rs2_option_to_string will be deprecated in future and rs2_get_option_name should be used instead.
Please visit this link to view the full details of the API changes.
https://github.com/IntelRealSense/librealsense/wiki/API-Changes#from-version-2181-to-2190
NEW FEATURES & IMPROVEMENTS
T265 Tracking Camera
  • T265 tracking camera support
  • Advanced T265 APIs - adding new sensors extensions allowing relocalization map load / store, static node set / get (coordinates transform between different maps) and wheel odometry input
  • Ability to unload tracking camera module - for better ROS and NCS compatibility
  • rs-pose - new example showing the basics of working with T265 tracking camera
NOTES:
  • The T265 tracking camera is not yet supported on Android and Mac-OS via librealsense. Support is planned to be added in a future release.
  • Wheel-odometry is required to meet performance of <1% loop closure error on wheeled robots.
  • T265 map internal format will change in future releases
  • Additional examples, white-papers and tutorials on advanced topics including wheel-odometry and relocalization map loading will be published in the future
Android
  • Android Play-Store support
  • Using peripheral RealSense cameras on Android no longer require the device to be rooted. This feature includes basic Java bindings, code samples and tools.
NOTES:
  • The T265 tracking camera and the D435i depth camera are not yet supported on Android via librealsense. Support is planned to be added in a future release.
Other
  • Automated Standards Enforcement - enforce basic project standards during CI
  • C# & Unity updates - multiple changes to the .NET wrapper, including support for motion and pose frames
  • Refactoring of options and filters API - allows different devices to advertise different post-processing capabilities.
  • API for adding software device into existing context - for development of better converters and 3rd-party depth sources
BUG FIXES
  • Added fstream dependency - contributed by @RanoVeder
  • Update python-rs400-advanced-mode-example.py - contributed by @skylouis
  • Replace vec2mat with reshape 2 - contributed by @changh95
  • DSO-11755 - Viewer crash when fail to set advanced mode setting
  • Cannot change AE mean intensity point in the Viewer
  • Cannot load JSON with RGB8 format in the Viewer
  • rs-convert does not terminate execution
  • rs-convert does not convert to PLY
  • Conditionally define STRINGIFY macro
  • Missing include in example.hpp
  • rs2_depth_frame_get_distance doesn't work for software_device sensor
  • YUY in the Viewer produces white image
The full release notes, with all linkages and a list of unresolved Known Issues, can be found here:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes#release-2190
