Items with no label
3340 Discussions
a thread to do filter process and main thread to view 3d point cloud in PCL
zting1
I wrote a program to do filter process and view 3d point cloud in PCL by the method of multi-threads based on the example of rs-measure. I can't find what's wrong with the program. the data flow is just like the rs-measure. Can you give me some advice? Thanks a lot!
code is below:
#include <librealsense2/rs.hpp> // Include RealSense Cross Platform API #include <librealsense2/rsutil.h> #include "example.hpp" // Include short list of convenience functions for rendering // This example will require several standard data-structures and algorithms: #define _USE_MATH_DEFINES #include <math.h> #include <queue> #include <algorithm> // std::min, std::max #include <thread> #include <atomic> #include <opencv2/opencv.hpp> // Include OpenCV API #include <mutex> //PCL #include <pcl/common/common_headers.h> #include <pcl/visualization/pcl_visualizer.h> #include <pcl/io/pcd_io.h> #include <pcl/filters/passthrough.h> typedef pcl::PointXYZRGB RGB_Cloud; typedef pcl::PointCloud<RGB_Cloud> point_cloud; typedef point_cloud::Ptr cloud_pointer; using pixel = std::pair<int, int>; //Global variable int width = 1280; int height = 720;   using namespace std; void getXYZfromUV(const rs2::depth_frame& frame,pixel u, float upoint[3], const rs2_intrinsics intr_,float depthScale); std::shared_ptr<pcl::visualization::PCLVisualizer> createRGBVisualizer(pcl::PointCloud<pcl::PointXYZRGB>::ConstPtr cloud); int main() {   rs2::align align_to(RS2_STREAM_COLOR); // Decimation filter reduces the amount of data (while preserving best samples) rs2::decimation_filter dec; // If the demo is too slow, make sure you run in Release (-DCMAKE_BUILD_TYPE=Release) // but you can also increase the following parameter to decimate depth more (reducing quality) dec.set_option(RS2_OPTION_FILTER_MAGNITUDE, 2); // Define transformations from and to Disparity domain rs2::disparity_transform depth2disparity; rs2::disparity_transform disparity2depth(false); // Define spatial filter (edge-preserving) rs2::spatial_filter spat; // Enable hole-filling // Hole filling is an agressive heuristic and it gets the depth wrong many times // However, this demo is not built to handle holes // (the shortest-path will always prefer to "cut" through the holes since they have zero 3D distance) spat.set_option(RS2_OPTION_HOLES_FILL, 5); // 5 = fill all the zero pixels // Define temporal filter rs2::temporal_filter temp;   // After initial post-processing, frames will flow into this queue: rs2::frame_queue postprocessed_frames;     // Declare RealSense pipeline, encapsulating the actual device and sensors rs2::pipeline pipe; rs2::config cfg; cfg.enable_stream(RS2_STREAM_DEPTH,width,height,RS2_FORMAT_Z16,30); // For the color stream, set format to RGBA // To allow blending of the color frame on top of the depth frame cfg.enable_stream(RS2_STREAM_COLOR, width,height,RS2_FORMAT_BGR8,30); // Start streaming with default recommended configuration auto profile = pipe.start(cfg); auto intr = profile.get_stream(RS2_STREAM_DEPTH).as<rs2::video_stream_profile>().get_intrinsics(); auto sensor = profile.get_device().first<rs2::depth_sensor>(); auto depthScale = sensor.get_depth_scale()*1000;//mm   // Alive boolean will signal the worker threads to finish-up std::atomic_bool alive{ true };   std::thread video_processing_thread([&]() { // In order to generate new composite frames, we have to wrap the processing // code in a lambda rs2::processing_block frame_processor( [&](rs2::frameset data, // Input frameset (from the pipeline) rs2::frame_source& source) // Frame pool that can allocate new frames { // First make the frames spatially aligned data = data.apply_filter(align_to);   // Decimation will reduce the resultion of the depth image, // closing small holes and speeding-up the algorithm data = data.apply_filter(dec);   // To make sure far-away objects are filtered proportionally // we try to switch to disparity domain data = data.apply_filter(depth2disparity);   // Apply spatial filtering data = data.apply_filter(spat);   // Apply temporal filtering data = data.apply_filter(temp);   // If we are in disparity domain, switch back to depth data = data.apply_filter(disparity2depth);   // Send the composite frame for rendering source.frame_ready(data); }); // Indicate that we want the results of frame_processor // to be pushed into postprocessed_frames queue frame_processor >> postprocessed_frames;   while (alive) { // Fetch frames from the pipeline and send them for processing rs2::frameset fs; if (pipe.poll_for_frames(&fs)) frame_processor.invoke(fs); } });   cloud_pointer cloud(new point_cloud); cloud->width = static_cast<uint32_t>( width ); cloud->height = static_cast<uint32_t>( height ); cloud->is_dense = false; cloud->points.resize( width*height ); // Create the PCL point cloud visualizer std::shared_ptr<pcl::visualization::PCLVisualizer> viewer = createRGBVisualizer(cloud);   while(!viewer->wasStopped()) { rs2::frameset data; postprocessed_frames.poll_for_frame(&data); // Wait for next set of frames from the camera if(data) { rs2::depth_frame depth = data.get_depth_frame(); for (int j = 0; j < height; ++j) { for (int k = 0; k < width; ++k) { pixel v; v.first = k; v.second = j; float point[3]; getXYZfromUV(depth,v,point, intr,depthScale); int index_pcl = j * width + k; cloud->points[index_pcl].x = point[0]; cloud->points[index_pcl].y = point[1]; cloud->points[index_pcl].z = point[2]; } } } viewer->updatePointCloud(cloud); viewer->spinOnce(10); } // Close the viewer viewer->close(); // Signal the processing thread to stop, and join // (Not the safest way to join a thread, please wrap your threads in some RAII manner) alive = false; video_processing_thread.join(); return 0; } void getXYZfromUV(const rs2::depth_frame& frame,pixel u, float upoint[3], const rs2_intrinsics intr_, float depthScale) { float upixel[2]; // From pixel // Copy pixels into the arrays (to match rsutil signatures) upixel[0] = u.first; upixel[1] = u.second; // Query the frame for distance // Note: this can be optimized // It is not recommended to issue an API call for each pixel // (since the compiler can't inline these) // However, in this example it is not one of the bottlenecks auto udist = frame.get_distance(upixel[0], upixel[1]); float depth_in_mm = udist * depthScale; rs2_deproject_pixel_to_point(upoint, &intr_, upixel, depth_in_mm); } /** * This function creates a PCL visualizer **/ std::shared_ptr<pcl::visualization::PCLVisualizer> createRGBVisualizer(pcl::PointCloud<pcl::PointXYZRGB>::ConstPtr cloud) { // Open 3D viewer and add point cloud std::shared_ptr<pcl::visualization::PCLVisualizer> viewer(new pcl::visualization::PCLVisualizer("PCL Realsense 3D Viewer")); viewer->setBackgroundColor(0.12, 0.12, 0.12); pcl::visualization::PointCloudColorHandlerRGBField<pcl::PointXYZRGB> rgb(cloud); viewer->addPointCloud<pcl::PointXYZRGB>(cloud, rgb); viewer->setPointCloudRenderingProperties(pcl::visualization::PCL_VISUALIZER_POINT_SIZE, 1.5); viewer->addCoordinateSystem(1.0); viewer->initCameraParameters(); return (viewer); }
Alexandra_C_Intel
Hi zting1, Thank you for your interest in the Intel RealSense cameras. Are you getting an error when you run this code? Regards, Alexandra
