Items with no label
3341 Discussions
RealSense SDK version 2.22.0 now available (many API changes and features / improvements added)
MartyG
Hi everyone,
Version 2.22.0 of the RealSense SDK is now available for download.
https://github.com/IntelRealSense/librealsense/releases/
API CHANGES
  • Global Camera Timestamp:
  • Add rs2_timestamp_domain::RS2_TIMESTAMP_DOMAIN_GLOBAL_TIME enumeration type that will be used as default when the HW timestamp is available via the appropriate metadata attribute.
  • Add rs2_sensor* rs2_get_frame_sensor function
  • Add RS2_OPTION_GLOBAL_TIME_ENABLED option
  • Depth units transformation - Processing block
  • rs2_processing_block* rs2_create_units_transform function
  • Add rs2_format::RS2_FORMAT_DISTANCE synthetic stream format
  • Add units_transform class
  • Add rs2_error * rs2_create_error functionality
  • Add pose_stream_profile class to handle T265 pose sensor.
  • Add frame::get_sensor() functionality
  • Add sensor_from_frame(frame f) functionality
  • GLSL Processing Blocks Module:
  • New header files with new API for GLSL-supported modules are added to include/librealsense2-gl directory
NEW FEATURES & IMPROVEMENTS
  • Introducing Global Camera Timestamp. The feature is a prerequisite for inter-cam synchronization and requires frame metadata attributes. The PR changes the default behavior of frame.get_timestamp() by returning the timestamp in RS2_TIMESTAMP_DOMAIN_GLOBAL_TIME.
  • New Module - GLSL Processing Blocks. This pull-request introduces auxiliary realsense2-gl module. It can be used to perform common SDK processing tasks on the GPU in a relatively generic way (vendor neutral, unlike CUDA) via GLSL shaders. In addition, it serves as a proof-of-concept for future SDK extensions beyond core API (Follow the PR link for in-depth introduction).
  • Adding common cross-platform USB back-end API. Initially, it will be used for cross-platform FW update API and tools. In the future the infrastructure will allow unified implementation for UVC / HID / TM2 for all the supported operating systems.
  • Promote TM2 Firmware 0.0.18.5715 - re-localization and tracking stability enhancements
  • T265: Re-enabling re-localization reports.
  • Android OS (Java): Add post-processing filters and demo.
  • Add realsense2-gl Debian distribution packages to support PR3654.
  • Adding rs2_get_frame_sensor function.
  • New T265 Example: Generate Depth map from T265 Stereo sensors with OpenCV.
  • Add a processing block to generate depth frame in metric format (RS5-4269)
  • Add comprehensive documentation to Python wrapper via Sphinx.
  • Unreal Engine 4 wrapper supports v4.22.
  • Adding software_device support to C# wrapper.
  • RealSense depth viewer community example
  • Python Documentation - sample code enhancement
  • C#: Expose T265-specific APIs (Localization map, Static node).
  • OpenCv: Fix missing RS2_FORMAT_DISPARITY32 handler.
BUG FIXES
  • T265: Pose record / playback to provide the required metadata attributes; Enable rs-enumerate-devices extract info from ROSBag record files.
  • D435i: Rectify invalid RGB-Depth extrinsic calibration produced by FW versions 5.10.13+.
  • Fix extrinsic graph multiplications order.
  • Fix D435i IMU extrinsic.
  • T265 FW: Fix potential issue with UNC paths and rc.exe.
Full release notes with all linkages and a list of unresolved Known Issues can be found at the link below:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes#release-2220
