Hi everyone,
Version 2.27.0 of the RealSense SDK is now available for download from the link below.
https://github.com/IntelRealSense/librealsense/releases/
API CHANGES
T265 Calibration Write APIs: Allow custom calibration to be provided to the device and committed to device flash memory. There is also a mechanism to roll-back to factory calibration. Currently these APIs are only implemented for the T265, but similar scheme is likely to be used for other families
- rs2_set_intrinsics - set video stream profile intrinsic calibration
- rs2_set_extrinsics - set extrinsic calibration between two stream profiles
- rs2_set_motion_device_intrinsics - set motion stream profile intrinsics
- rs2_reset_to_factory_calibration - Resets the device to factory calibration when available
- rs2_write_calibration - Commit calibration changes to device flash memory
- rs2_clone_video_stream_profile - Utility function used when developing custom processing blocks that modify video stream resolution
NEW FEATURES & IMPROVEMENTS
T265 Calibration APIs:
- #4650 - write calibration APIs
- #4717 - updating default T265 firmware to 0.1.0.279
Expose the ability to modify the T265 calibration (w/ #4650)
T265 tracking performance improvement
Fixes #4700 T265 load/start/stop/load/start failure
- #4739 and #4685 - documentation enhancements
- New OpenCV example - #4733 (Implementing "Depth Map Improvements for Stereo-based Depth Cameras on Drones")
- #4721 - Fix format-security warnings (contributed by @morxa)
- #4706 - [Viewer] Enable step forward and backward during playback
BUG FIXES
- On-Chip Calibration enhancements
- Integration with firmware 5.11.14 (pre-release)
- Unlocking the feature for D435i
- Fixing Tare calibration units
- #4731 - Fixing Java example
- #4729 - Fix Ubuntu 32bit compilation
- #4698 - [Android] GLFrame resource release
For full linkages and a list of unresolved Known Issues, you can read the full release notes here:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes#release-2270
