Items with no label
3338 Discussions
Realsense D415 hangs after one use on Linux
KWilc
I'm trying to use D415 with realsense-viewer. I'm on Ubuntu 18.04 (kernel 4.15.0.XX), so I downloaded and built
development branch librealsense2 SDK using instructions from the Github:
https://github.com/IntelRealSense/librealsense/tree/development GitHub - IntelRealSense/librealsense at development
https://github.com/IntelRealSense/librealsense/blob/development/doc/installation.md librealsense/installation.md at development · IntelRealSense/librealsense · GitHub
The issue I have is that the camera run only once: in realsense-viewer I start streaming from the stereo cameras and/or
RGB camera, then I stop the streaming. When trying to stream again, the system is missing frames, nothing is streamed.
Only hardware reset or replugging the USB cable helps.
I run some usbmon and found that the USB frames are not sent after the first stream is stopped, nothing is sent on
the bus. But the device is not completely hanged, because it can be reset using hardware reset option from the Viewer.
Does someone have any ideas what might be wrong?
I attached a screencast demonstrating the issue.
Device info:
Name : Intel RealSense D415
Serial Number : 802212061216
Firmware Version : 05.09.11.00
Recommended Firmware Version : 05.09.09.02
Physical Port : /sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb2/2-7/2-7:1.3/video4linux/video5
Debug Op Code : 15
Advanced Mode : YES
Product Id : 0AD3
Usb Type Descriptor : 3.1
Best Regards
Kamil
MartyG
Sporadic issues that require a hardware unplug-replug or a hardware reset to correct are a Known Issue in the firmware that Intel continues to work on.
On a discussion about these issues (link below), someone found that their particular problems disappeared if they used the camera with a mains-powered USB 3.0 hub.
https://github.com/IntelRealSense/librealsense/issues/1213 Sporadic errors, only workaround is to physically reconnect camera · Issue # 1213 · IntelRealSense/librealsense · GitHub
