Items with no label
3341 Discussions
Realsense Package Error using Ubuntu and UP board
DVarh
I have the following issue.
On a fresh installation of Ubuntu on UP board and UP core, the Realsense packages found on this link https://github.com/IntelRealSense/librealsense/blob/master/doc/distribution_linux.md https://github.com/IntelRealSense/librealsense/blob/master/doc/distribution_linux.md do not work.
After the first 4 bullet points on the instructions of that link are complete, and we try to run 'realsense-viewer', an error returns saying 'Illegal instruction (core dumped)'.
I can build and compile the library manually using the source code from the github repository, but this takes a long time and would be nice to avoid it.
Any feedback from the community or the Intel engineers would be very appreciated!
Thank you!
MartyG
Others have reported the same error - 'Illegal instruction (core dumped)' - on the Librealsense forums when trying to use the pre-made build but were able to build from source like you. From what I can gather from the post linked to below. the latest version of the SDK (2.10.2) has some issues with Up Boards due to a change the developers made, and they are looking to fix it. They recommended using 2.10.1 in the meantime.
https://github.com/IntelRealSense/librealsense/issues/1428 Illegal instruction on Up Squared computer with Pentium processor · Issue # 1428 · IntelRealSense/librealsense · GitHub
That was 11 days ago. Several days ago there was another related case.
https://github.com/IntelRealSense/librealsense/issues/1464 realsense-viewer Illegal instruction (core dumped) · Issue # 1464 · IntelRealSense/librealsense · GitHub
