Items with no label
3338 Discussions
Rear vs front view camera definition
AVolo6
Hi, I am trying to figure out if there is a way to tell SR300 that it is a rear view camera?
It is not clear to me when does it show mirror-less image and when it shows mirror-like image?
I hope the question is clear enough,
thank you,
Alex.
MartyG
If you are using the RealSense SDK in Windows, you can use the QueryMirrorMode instruction to find out which orientation the image is in.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?querymirrormode_device_pxccapture.html Intel® RealSense™ SDK 2016 R2 Documentation
This instruction is categorized as being 'device neutral', meaning that it likely works with any RealSense camera model.
The orientation can be set with SetMirrorMode.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?setmirrormode_device_pxccapture.html Intel® RealSense™ SDK 2016 R2 Documentation
Below is an example C# script that demonstrates the use of SetMirrorMode (see the bottom of the script).
https://software.intel.com/es-es/node/597711# comment-1846777 https://software.intel.com/es-es/node/597711# comment-1846777
AVolo6
Thank you very much for your fast reply. I will check it over the weekend and will let you know
Thank you,
Alex.
