Items with no label
3341 Discussions
Recording Video in 60fps with threading and queue (Python)
SHuan76
Sorry for my poor English.
I asked how to get 60fps RGB video stream before.
Now I want to record the RGB stream into a video, but I want to separate the step of getting RGB image and the step of writing them into video.
So I use threading and queue to implement it.
The concept is that the camera catch RGB image in 60fps, putting them into rgb_queue, and the other thread called RecordingJob get the images from rgb_queue, writing them into video continuously.
Unfortunately, when I run the code, the error Frame didn't arrived within 5000 usually happens.
For example, I would like to record a 5-min video(18000frames), but the code stuck at the 173th frame, the RecordingJob only write 160 frames into video, and 13 frames are still in rgb_queue.
If RecordingJob just get the images from queue and doesn't write them into video, the code can be run without error.
If I just get an image and write it into video directly in 60fps, the code can be executed without error, too.
I wanna know how to solve the problem, thank you in advance for your apply.
My code is attached below.
MartyG
Your English is excellent, so do not worry. :)
The RealSense forum has moved to a new location, and the Intel support staff are no longer answering at this old forum. I recommend posting your question again at the new forum please so that Intel support staff can provide you with assistance. Thanks!
https://support.intelrealsense.com/hc/en-us/community/topics
SHuan76
Thanks for your information, I'll post it there.
