Items with no label
3338 ディスカッション
SDK examples not working on Up Board (Robotic Kit) with Windows 10
AndreCarlucci
ビギナー
1,900件の閲覧回数
I installed Windows 10, the RealSense SDK, DCM, it installs just fine.
But no SDK example works...
Any thoughts?
0 件の賞賛
1 解決策
従業員
962件の閲覧回数
Hi Andrecarlucci,
Thanks for contacting us!
We appreciate all the information provided. We would like to let you know that according to the release notes of the SDK and DCM, Intel® Core™ processors are required, and the Up Board has Atom, so this is an unsupported configuration. Moreover, we'd suggest to use librealsense since it is supported as you already know.
Our apologies for any inconvenience it may cause.
-Yermi A.
元の投稿で解決策を見る
2 返答(返信)
AndreCarlucci
ビギナー
963件の閲覧回数
I tried a small program that just create the session and the manager to start looping through frames.
When I try to enable any module, I get the PXCM_STATUS_ITEM_UNAVAILABLE
The camera appears on the Device Manager (Depth, RGB and the Virtual Driver).
I tried an example with librealsense and it works juts fine.
Could anyone run the RealSense SDK on Windows 10?
従業員
963件の閲覧回数
Hi Andrecarlucci,
-Yermi A.
返信
