Items with no label
3341 討論
SR200 not detected on upboard running on Windows 10 64bits
hnort1
初學者
3,460 檢視
I try to install "intel_rs_dcm_r200_2.1.27.2853" but I always have the same error : "No realsense 3D camera detected".
I use an upboard running on Windows 10 64bits, and a rs200 camera.
Is it an issue comming from th camera or from the upboard?
I tried on an Asus PC , it works properly.
1 解決方案
MartyG
榮譽貢獻者 III
1,931 檢視
When you say you are running it on an upboard, do you mean this?
http://www.up-board.org/up/ Up Board | Power Up Your Ideas!
If so, that board uses an Intel Atom x5-Z8350 processor. Although the SR-300 works on Windows 10, it also requires a minimum processor spec of Intel Core 6th generation Skylake. Sadly, that is likely why it works on your Asus but not on the Up board.
Often, you may be able to do basic processing of raw camera data or RGB video with RealSense if your processor does not meet the specification, even if you cannot access RealSense's other advanced functions such as scanning and tracking. In the case of Up board though, the camera is not detected, Apparently, the board uses a form of USB 3.0 called OTG (On The Go), which is a kind of USB adapter. RealSense is very sensitive in regards to the USB ports it will work with, and so there may be some aspect of the OTG that is causing the camera not to be detected.
在原始文章中檢視解決方案
3 回應
MartyG
榮譽貢獻者 III
1,932 檢視
AndreCarlucci
初學者
1,931 檢視
If the camera is not supported, why there is an option called "enable SR300 camera support" on the BIOS menu?
員工
1,931 檢視
Hi andrecarlucci,
There's a thorough explanation of the RealSense cameras supported by the Up Board in this link: https://communities.intel.com/thread/106663 https://communities.intel.com/thread/106663 .
We hope you find this information helpful.
-Sergio A
回覆
