Hi, Sir
I try to setting the SR300 color and depth stream at 1920x1080 30 fps .
but the image show 17 fps at 1920x1080, below the photo1,
when I setting 640x480 the image show 30 fps
Q. At 1920x1080, could i setting 30 fps and how to check it is true ?
It's my testing code
# include
# include
# include "util_render.h"
# include
# define COLOR_WIDTH 640//1920
# define COLOR_HEIGHT 480//1080
# define DEPTH_WIDTH 640
# define DEPTH_HEIGHT 480
void main()
UtilRender *renderColor = new UtilRender(L"COLOR_STREAM");
UtilRender *renderDepth = new UtilRender(L"DEPTH_STREAM");
PXCSenseManager *psm = NULL;
psm = PXCSenseManager::CreateInstance();
if (psm == NULL) {
std::cout << "Unabel to create the PXCSenseManager" << std::endl;
return;
PXCSession::ImplVersion version = psm->QuerySession()->QueryVersion();
std::cout << "SDK Version:" << version.major << version.minor << std::endl;
psm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, COLOR_WIDTH, COLOR_HEIGHT,30);
psm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, DEPTH_WIDTH, DEPTH_HEIGHT, 30);
if (psm->Init() != PXC_STATUS_NO_ERROR) {
std::cout << "Unable to Init the PXCSenseManager" << std::endl;
return;
PXCImage *colorIm, *depthIm;
while (true)
if (psm->AcquireFrame(true) < PXC_STATUS_NO_ERROR)
break;
PXCCapture::Sample *sample = psm->QuerySample();
if (sample)
if (sample->color)
colorIm = sample->color;
if (!renderColor->RenderFrame(colorIm))
break;
if (sample->depth)
depthIm = sample->depth;
if (!renderDepth->RenderFrame(depthIm))
break;
psm->ReleaseFrame();
psm->Release();
链接已复制
