Items with no label
3338 Discussions
SR300 color and depth stream fps question
ewu12
Hi, Sir
I try to setting the SR300 color and depth stream at 1920x1080 30 fps .
but the image show 17 fps at 1920x1080, below the photo1,
when I setting 640x480 the image show 30 fps
Q. At 1920x1080, could i setting 30 fps and how to check it is true ?
It's my testing code
# include
# include
# include "util_render.h"
# include
# define COLOR_WIDTH 640//1920
# define COLOR_HEIGHT 480//1080
# define DEPTH_WIDTH 640
# define DEPTH_HEIGHT 480
void main()
UtilRender *renderColor = new UtilRender(L"COLOR_STREAM");
UtilRender *renderDepth = new UtilRender(L"DEPTH_STREAM");
PXCSenseManager *psm = NULL;
psm = PXCSenseManager::CreateInstance();
if (psm == NULL) {
std::cout << "Unabel to create the PXCSenseManager" << std::endl;
return;
PXCSession::ImplVersion version = psm->QuerySession()->QueryVersion();
std::cout << "SDK Version:" << version.major << version.minor << std::endl;
psm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, COLOR_WIDTH, COLOR_HEIGHT,30);
psm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, DEPTH_WIDTH, DEPTH_HEIGHT, 30);
if (psm->Init() != PXC_STATUS_NO_ERROR) {
std::cout << "Unable to Init the PXCSenseManager" << std::endl;
return;
PXCImage *colorIm, *depthIm;
while (true)
if (psm->AcquireFrame(true) < PXC_STATUS_NO_ERROR)
break;
PXCCapture::Sample *sample = psm->QuerySample();
if (sample)
if (sample->color)
colorIm = sample->color;
if (!renderColor->RenderFrame(colorIm))
break;
if (sample->depth)
depthIm = sample->depth;
if (!renderDepth->RenderFrame(depthIm))
break;
psm->ReleaseFrame();
psm->Release();
jb455
Valued Contributor II
You could be limited by the rendering speed - comment out the RenderFrame lines and see if it gets up to 30fps then.
Hi Wu,
Let us know your results once you try jb455's suggestion, we would like to know if you get better results by doing that.
Jb455, thank you very much for your help on this thread.
-Pablo M.
We would like to know if you have updates on this case. Have you tried the suggestions?
Pablo M.
