Items with no label
3339 Discussions
T265 crashes every 5-10 minutes
CAnde23
When running a program using the latest T265 Python libraries, the sensor crashes every 5-10 minutes with this error. I'm running it with a standard Intel NUC under Ubuntu 18. Anybody know what's going on?
10:42:23.370 [3429] [E] Device-6B80: FW crashed - got error in stream endpoint thread function: status = -1 (LIBUSB_ERROR_IO), actual = 0
10:42:23.382 [3428] [E] Device-6B80: FW crashed - got error in interrupt endpoint thread function: status = -1 (LIBUSB_ERROR_IO), actual = 0
10:42:23.570 [3422] [E] Device-6B80: State [ACTIVE_STATE] got event [ON_ERROR] ==> [ERROR_STATE]
10:42:23.570 [3422] [E] Device-6B80: Entered state [ERROR_STATE]
MartyG
A good starting point may be to look at the discussion in the link below, with a T265 user who experienced a similar set of errors.
https://github.com/IntelRealSense/librealsense/issues/3756
If you did kernel patching as part of your T265 setup process, Dorodnic the RealSense SDK Manager also advises that patching is not necessary with T265.
https://github.com/IntelRealSense/librealsense/issues/3517#issuecomment-475131108
