Items with no label
3340 Discussions
What is the fastest possible time it takes to, using code, access a camera and then get a depth frame?
KChow4
I was testing with the D415 camera to find out how long it took, via code, to access the camera device and capture a single frame.
When testing using the code snippet below, I noticed that it actually took a second or so to do this.
Do RealSense cameras normally take this long to run code like this and is there a faster way to access the camera and take a frame using code (aside from dropping the number of frames that it waits for when stabilizing)?
Thanks in advance!
// Declare RealSense pipeline, encapsulating the actual device and sensors rs2::pipeline c_pipe; //Set the configurations rs2::config c_cfg; c_cfg.enable_device(serial_no); //Changes in the resolution of the stream c_cfg.enable_stream(RS2_STREAM_COLOR, 848, 480, RS2_FORMAT_BGR8, 30); // Start streaming with the defined configurations c_pipe.start(c_cfg); //Declaration of frameset rs2::frameset data; //Stablize frames for (int i = 0; i < 30; i++) { data = c_pipe.wait_for_frames(); }   //Get frame rs2::frame colour = data.get_color_frame();
MartyG
I went over your code and could not see any obvious problems.
The SDK documentation's section on latency may give some useful insight.
https://github.com/IntelRealSense/librealsense/wiki/Frame-Buffering-Management-in-RealSense-SDK-2.0#latency-vs.-performance
KChow4
Thanks, I will check it out!
