Items with no label
3341 Discussions
buy default 1m cable?
mj000111111
my intel realsense d435 1m USB 3.1 cable got damaged. where Can I buy this same cable in germany? It is very urgent.
thanks.
MartyG
An excellent supplier in Germany for RealSense parts is Rutronik, who are an Intel Authorized Distributor.
They have in stock a 1 m USB 3.1 USB-A to Type-C cable like the one used with the camera, though it is not inexpensive.
https://www.rutronik24.de/produkt/alysium/a74-9857/9707719.html
Beware of buying cheap cables that may not be of good quality, or may be meant for use only as charging cables rather than full-capability USB cables.
mj000111111
they only sell to company not private customers.
MartyG
I have not heard that about Rutronik before.
I checked other Intel Authorized distributor sources, and found that Arrow's German site has a USB A to USB C cable for 14 Euro.
https://www.arrow.de/products/u428-003-cra/tripp-lite
It would also be straightforward to order a USB A to C cable from Amazon.de if that is an option available to you. Search it for 'usb type-a to type-c cable'.
MartyG
I'm concerned that the less expensive options may only be suitable for device charging rather than use as a full USB 3.1 data transfer cable.
This one looks like a better option:
https://www.amazon.de/MCL-mc923-1-3ame-1-3-1-Typ-m%C3%A4nnlich/dp/B017GWXCMM/ref=sr_1_13?__mk_de_DE=%C3%85M%C3%85%C5%BD%C3%95%C3%91&keywords=usb%2B3.1%2Btyp%2Bc%2Bauf%2Btyp%2Ba%2Bkabel&qid=1560337246&refinements=p_36%3A428371031&rnid=428358031&s=computers&sr=1-13
MartyG
That looks like exactly the kind of cable you need, one capable of supporting heavy data transfer like external hard drives.
mj000111111
thank you. done. I hope it work like default cable.
MartyG
It seems to be a high-quality, high-specification cable, so it should work. Good luck!
JesusG_Intel
As of June 10, 2019, Intel® RealSense™ product support has moved to https://support.intelrealsense.com. All new community posts must be submitted at https://support.intelrealsense.com. If you have existing threads on this Forum that were opened before June 10, 2019 and are not resolved, please re-post your question at https://support.intelrealsense.com. This Forum will continue to be searchable after the cutover.
You will still be able to create questions on this forum but those questions will not receive support from Intel. If you desire Intel support, please go to https://support.intelrealsense.com.
