Items with no label
3340 Discussions
convert depth image to point cloud
fwang22
How to convert depth frame to point cloud using Matlab? I know one way is if we know the camera parameters,we can obtain point cloud .But what are the parameters ?or Is there any other way to do it in Matlab?
fwang22
Hello MartyG,
when I run the rs-convert.exe .there has an error,
the rs-convert.exe was build from version 2.16.1,but I don't know how to solve it.
MartyG
I haven't encountered this particular error with the convert tool, but there was a previous case where there was problems with it. This related to the path instructions provided to the program.
Looking at your image, I would recommend trying one conversion at a time, instead of both -i and -l. For example, to convert the bag to ply:
rs-convert.exe -l F:\pointcloud\pointcloud\samples\expression\4\anger
fwang22
Hello MartyG,
I installed SDK version 2.16.1, and I use the version 2.16.1 source code to build rs-convert.exe, but the same error was showed as above, I want to know Rosbag fixes were added in RealSense SDK version 2.16.1.,Do I need to rebuild rs-convert.exe to obtain full frames by version 2.16.1 source code ?
MartyG
As the rs-convert tool's source code is separate from the SDK package, you likely do not have to recompile it when upgrading SDK version.
fwang22
In other words, the problem of missing frames has been solved in new SDK, we don't need to recompile re-convert to convert the .bag files.
MartyG
I suggest giving it a try and letting us know what the results are in 2.16.1. Thanks!
fwang22
I tried some data and the results were as follows:
Some samples lose frames,most do not.
MartyG
Thanks for the quick response. Are you satisfied with these results, please?
fwang22
unfortunately, when I change the viewer resolution and FPS, the results are not satisfied.
the resolution is 848*480, FPS is 60.
MartyG
I would recommend posting your results on the open discussion about rs-convert frame drop problems on the GitHub.
https://github.com/IntelRealSense/librealsense/issues/1919 problems in rs_convert · Issue # 1919 · IntelRealSense/librealsense · GitHub
