Items with no label
3338 Discussions
full sample code for 3DScan in C#
SJung11
hello, I work with realsense
I want to 3D Scan with SR300 and R200
I read 'Coding 3D Scanning' in the 'RealSense SDK 2016 R2 Documentation'
but i don't know what do i have to write in 'ㆍㆍㆍ'
so i want to get a full sample code for 3D Scan and save mesh file in C# (WPF / FORM)
help me, send a full sample code !! please
kkeye
this is my code work with unity, I hope useful for you. if you use wpf or form you convert _previewData to bitmap
void Start()
Mgt_AppSession.SM = SenseManager.CreateInstance();
if (Mgt_AppSession.SM == null)
Mgt_Message.Msg_Error("Sense Manager 创建失败");
return;
if (Mgt_AppSession.SM.CaptureManager == null)
Mgt_Message.Msg_Error("Capture Manager 不存在");
return;
Mgt_AppSession.SM.CaptureManager.FilterByStreamProfiles(StreamType.STREAM_TYPE_DEPTH, DepthWidth, DepthHeight, FrameRate);
Mgt_AppSession.ScanModule = Scan3D.Activate(Mgt_AppSession.SM);
if (Mgt_AppSession.ScanModule == null)
Mgt_AppSession.SM.Close();
Mgt_AppSession.SM.Dispose();
Mgt_Message.Msg_Error("Scan3D 模块激活失败");
return;
var initStatus = Mgt_AppSession.SM.Init();
if (initStatus < Status.STATUS_NO_ERROR)
Mgt_Message.Msg("Sense Manager 初始化失败", initStatus);
return;
Mgt_AppSession.ScanConfig = new Configuration();
Mgt_AppSession.ScanConfig.mode = ScanningMode.VARIABLE;
Mgt_AppSession.ScanConfig.maxVertices = 0;
Mgt_AppSession.ScanConfig.maxTriangles = 0;
var scanConfigStatus = Mgt_AppSession.ScanModule.SetConfiguration(Mgt_AppSession.ScanConfig);
if (scanConfigStatus < Status.STATUS_NO_ERROR)
Mgt_AppSession.ScanModule.Dispose();
Mgt_Message.Msg("Scan3D 选项配置失败", scanConfigStatus);
_imgControl = GameObject.Find("RawImage").GetComponent();
Mgt_AppSession.MeshFilePath = string.Format("{0}", System.Environment.CurrentDirectory);
Mgt_AppSession.IsStreaming = true;
void Update()
if (!Mgt_AppSession.IsStreaming)
return;
if (Mgt_AppSession.SM.AcquireFrame(true).IsSuccessful())
ImageData _previewData;
var previewImage = Mgt_AppSession.ScanModule.PreviewImage;
var previewImageStatus = previewImage.AcquireAccess(ImageAccess.ACCESS_READ, PixelFormat.PIXEL_FORMAT_RGB32, out _previewData);
if (previewImageStatus == Status.STATUS_NO_ERROR)
var image = _previewData.ToTexture2D(0, previewImage.Info.width, previewImage.Info.height);
_imgControl.texture = image;
image.Apply();
previewImage.ReleaseAccess(_previewData);
else
Mgt_AppSession.IsStreaming = false;
Mgt_Message.Msg("图像获取失败", previewImageStatus);
previewImage.Dispose();
Mgt_AppSession.SM.ReleaseFrame();
SJung11
I appreciate your kindness
but i don't know how do i conver _previewData to bitmap ??
If you are ok, can you tell me the way?
Thanks, JY_JIAO
jb455
Valued Contributor II
If you have the SDK installed, open up "RealSense SDK Sample Browser", go to the Common Samples tab, click C# on the left then find 3D Scan and click Sources next to it. You'll have the full source code then.
Hi Suho,
Thanks for reaching out.
I think that there is a lot of information that can be helpful for you, but practically it is like Jb455 said.
These are some helpful links:
https://software.intel.com/sites/default/files/Getting_Started_0.pdf
https://software.intel.com/sites/default/files/managed/41/4e/sdkdevguide.pdf
https://software.intel.com/en-us/articles/get-started-developing-intel-realsense-sdk-for-windows-10-desktop-apps
https://software.intel.com/en-us/articles/using-the-intel-realsense-sdk-to-create-hello-world-project
Have a nice weekend.
-Leonardo
Hi Suho,
Were the links helpful? Do you still have issues with the code?
Please let us know.
-Leonardo
SJung11
yes, Sorry for late ...
Thanks !!!
Hi Suho,
Awesome! Feel free to contact us if you have issues.
-Leonardo
