Items with no label
3338 Discussions
how to get (x,y,z) from depth image".raw"
czhen7
hi!
I have a project to measure the height of soybeans. With D435, we have obtained depth images—saved by ".raw" .
Can we get the coordinates of a certain point in the real world from the depth image, if possible,how to get it????
thank you!!
MartyG
The subject of getting the depth value from a .raw file has been discussed on the RealSense GitHub.
https://github.com/IntelRealSense/librealsense/issues/2231# issue-350003900 How to get the depth value corresponding to the color in the depth image? · Issue # 2231 · IntelRealSense/librealsense · …
There is a script below for getting XY measurements using the instruction deproject_pixels_to_point (which converts 2D pixel coordinates to 3D world coordinates), but I am not sure how to apply it to extracting XY from a .raw file.
https://github.com/IntelRealSense/librealsense/issues/1413# issuecomment-375265310 deprojection pixels to 3d point · Issue # 1413 · IntelRealSense/librealsense · GitHub
czhen7
OK I will try !
another question is can I use librealsense SDK 2.0 with ".raw" file , such as
align_to = rs.stream.color
MartyG
This link describes how to align saved files:
https://github.com/IntelRealSense/librealsense/issues/1274# issuecomment-370226116 upload color and depth images and then align them · Issue # 1274 · IntelRealSense/librealsense · GitHub
czhen7
I've read your reply , but the methods that 1274# metioned are:
1。rs2::software_device
2。rs2_deproject_pixel_to_point
3。 use.bag file
1 and 2 are deal with stream .Can I use stream to deal with the saved ".raw"???????????
I don't save pointcloud data ,so i don't have ".bag" file.
MartyG
Could you explain more please about what you are trying to achieve? Thanks!
czhen7
I'm so sorry about my bad description!!!
I want to measure the soybean's height using the depth image.
These images are taken above the soybean.
First , I should find the highest point and a point on ground.
But I only have distances between points and camera.
I don't know how to find the angle from one point to camera then to another point.
If successful ,I can use vector to calculate the height.
It's better if I get the (x , y , z) in the real world.
ps.
I only have the ".raw" file ,color ".png" and depth ".png".
thanks a lot!!!!
MartyG
May I ask first if it is a required part of your project that you create image files. Or do you not have access to a camera and have to do the calculations using image files only. This is because there are already existing measuring programs for the 400 Series cameras.
Measure (C++)
https://github.com/IntelRealSense/librealsense/tree/master/examples/measure librealsense/examples/measure at master · IntelRealSense/librealsense · GitHub
Box Dimensioner (Python)
https://github.com/IntelRealSense/librealsense/tree/master/wrappers/python/examples/box_dimensioner_multicam librealsense/wrappers/python/examples/box_dimensioner_multicam at master · IntelRealSense/librealsense · GitHub
czhen7
I already have access to a camera but have to do the calculations using image files only. Because the soybean have been almost riped, I don't have the right time .
MartyG
It would probably be quite easy if you could have recordings provided to you in the .bag format. This is because the SDK's sample programs can run off a bag file recording instead of the camera if you make a simple three-line change to the program.
https://github.com/IntelRealSense/librealsense/blob/master/doc/sample-data.md librealsense/sample-data.md at master · IntelRealSense/librealsense · GitHub
But am I right in thinking that it is too late to record a bag and you now have only the images to work with?
MartyG
I spent a few hours trying to work out a process that will work for you. I believe the basic steps are:
STEP ONE
Get your color and depth file images aligned.
STEP TWO
Convert the aligned image into a point cloud using the instruction deproject_pixel_to_point
STEP THREE
RealSense's SDK Manager, Dorodnic, has suggested using the SDK's point cloud example program to get the XYZ real-world coordinates, as "the output of pointcloud object is a collection of {x,y,z} coordinates in the real world".
https://github.com/IntelRealSense/librealsense/tree/master/examples/pointcloud librealsense/examples/pointcloud at master · IntelRealSense/librealsense · GitHub
I wish I could give more detail, but advanced RealSense programming is not one of my areas of expertise. If you get stuck, I would advise asking a question on the RealSense GitHub website. you can do this by going to the link below and clicking the 'New Issue' button.
https://github.com/IntelRealSense/librealsense/issues Issues · IntelRealSense/librealsense · GitHub
Edit: a shortcut may be to use the program below with the ROS software to convert a collection of images into a bag file.
https://github.com/raulmur/BagFromImages GitHub - raulmur/BagFromImages: Create a rosbag from a collection of images
czhen7
Thanks for your time!!I would try with your guide! ! !
Thanks!
