i need to setup 3.26.1.0 version Firmware for sr305
i found the "SR3XX_FW_Image-3.26.1.0" file and when i try to setup
realsense viewer open error popup
as you can see ;
the firmware download link is here :
- Tags:
- Intel® RealSense
Please post future RealSense questions to the new RealSense forum at the link below, as the RealSense forum on this site is no longer in use. Thanks!
https://support.intelrealsense.com/hc/en-us/community/topics
It is recommended that you select the 'Install recommended firmware' option from the RealSense Viewer's menu to automatically install the SR305 firmware that Intel recommend. You do not need a firmware file for this option, as the Viewer installs it for you.
