Items with no label
3340 Discussions
how to install pyntcloud in python 3 ?
tguan
i want to install pyntcloud in python 3
windows10
MartyG
For people who wish to contribute help to this case, it is a continuation of a previous question by guantong about how to install Pyntcloud. Read downward from the link below.
Hi guantong, are you still getting the same errors as you did before when you try to install Pyntcloud?
MartyG
tguan
thank you ,i install git and tried again as you tell me and installed succefully:
in cmd:pip install git+https://github.com/daavoo/pyntcloud https://github.com/daavoo/pyntcloud
two days ago ,i do the same steps but failed.
thank you
MartyG
Sometimes an installation fails, and then it works when trying again at a later date. So Pyntcloud is working for you now, please?
tguan
i have another question:
ImportError: cannot import name 'PyntCloud'
MartyG
My research into your question suggests that ImportError problems with Python seem to be difficult to solve. One suggestion is to put 'python -m' at the start of the pip install instruction to make sure that the library is installed into the default version of Python on your computer, and not another Python interpreter. So the Pyntcloud install instruction would look like this:
python -m pip install git+ https://github.com/daavoo/pyntcloud
tguan
still does not work...
i am using anaconda
MartyG
The bottom line of the log says that Pyntcloud has been successfully built. I am not sure what the next step after that is though. A post (linked to below) in which the creator of Pyntcloud replies seems to suggest that once installation is complete, you should go to the root location of the Pyntcloud repository and use
python setup.py install
https://github.com/daavoo/pyntcloud/issues/171 Installation guidelances · Issue # 171 · daavoo/pyntcloud · GitHub
If that does not work for you, I recommend re-opening that linked discussion on GitHub and leaving a comment for the creator, Daavoo.
