Items with no label
3338 Discussions
how to turn off auto_exposure and set a exposure value on D415
GLin21
I am using the python wrapper for a project, where I want to set the enable_auto_exposure first so that the camera can adjust to the proper exposure value, then disable the setting and confirm to use the adjusted exposure. However, it does not work. It seems like the auto_exposure only adjust something else but actually not tuning the exposure value.
could someone show me the example code ?
MartyG
There was another discussion where somebody was turning off auto-exposure and using manual exposure. You may be able to adapt their code to achieve your goal.
For example, you could first disable automatic exposure with sensor.set_option(RS2_OPTION_ENABLE_AUTO_EXPOSURE, false);
Then get the current exposure (the last value set before auto-exposure was disabled):
sensor.get_option(RS2_OPTION_EXPOSURE);
And make a custom-named manual exposure variable (such as the new_exposure used in that linked-to case) equal to the current exposure value above. Something like this structure:
new_exposure = sensor.get_option(RS2_OPTION_EXPOSURE)
And set the exposure manually using that custom variable:
sensor.set_option(RS2_OPTION_EXPOSURE, new_exposure);
RZ1
Hi
I have problem to set the exposure sensor.get_option(RS2_OPTION_EXPOSURE).
in order to do that i have to install pysensor via pip which give an error.
Thanks for help
Collecting PySensors
Using cached https://files.pythonhosted.org/packages/4e/11/c17454160e80a60587adcb511b760a6ddf8b2d60683bb0edd85919199adf/PySensors-0.0.3.tar.gz
Complete output from command python setup.py egg_info:
Traceback (most recent call last):
File "", line 1, in
File "c:\users\appdata\local\temp\pip-install-fhhqvm\PySensors\setup.py", line 4, in
import sensors
File "sensors\__init__.py", line 19, in
SENSORS_LIB = CDLL(LIB_FILENAME)
File "c:\users\appdata\local\continuum\anaconda2\lib\ctypes\__init__.py", line 366, in __init__
self._handle = _dlopen(self._name, mode)
TypeError: expected string or Unicode object, NoneType found
Command "python setup.py egg_info" failed with error code 1 in c:\users\appdata\local\temp\pip-install-fhhqvm\PySensors\
MartyG
Hi rzz96,
I see you have received a response from Dorodnic, the RealSense SDK Manager, on your GitHub version of this question. Dorodnic is best placed to give an answer to this subject. Please follow up with him on the GitHub if you have further questions on this subject. Thanks!
