Items with no label
3341 Discussions
i have an old core2duo E4500 and it is suppoused to run at 1.5 - 2.2 GHZ but i had a really hard load and it rant at 0.120 - 2.8 GHZ and i dont know if it is normal.
JVomo
AlHill
Old is correct, from 2007.
What OS? WIndows 10? What version? 1909?
What is the model number of your system/motherboard?
Have you cleaned the heat sink/cooler recently? Have you reapplied the thermal paste?
Have you checked the disk for errors and failing?
How much Memory do you have and have you checked for memory failure?
There are many things that can be happening on a processor this old. You need to answer each question and provide DETAILS.
Doc
JVomo
i have win 7 64bit, motherboard dell inc. 0wk833. i cleaned cooler last month and thermal paste... it was never changed ,from date we installed the CPU to PC: (approx. 10-12 years). disk is ok, and memory 8gb ddr3 is ok too
JVomo
and i never had this problem
AlHill
  1. Windows 7 is dead and not supported.
  2. I do not know that you can believe that utility.
Is everything on your PC running, and are you just concerned about what that utility reports?
Doc
JVomo
i believe it like 30% and i was only doing word youtube (720p) and minecraft
AlHill
I do not understand what you are saying.
Also, what anti-virus do you have?
Doc
JVomo
i have bitdefender
AdrianM_Intel
Hello JVomo,
Thank you for posting on the Intel® communities.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
Adrian M.
A Contingent Worker at Intel
