Items with no label
3338 Discussions
is it possible to track velocity with the T265?
HDiet
is it possible to track the velocity of my robot with the T265 attached on that robot? The T265 looks at the ground with a distance of 200mm to the ground. The velocity of my robot is between 5 and 70cm/minute and the traveled distance is max. 2m. What is the accuracy of the tracked velocity?
best regards, hanzdieter
MartyG
The T265 can produce samples containing linear and angular velocity with its '6DOF Pose' feature. The pose is hardware-generated at 262 Hz. Intel have produced a guide to getting IMU data from the D435i or T265.
https://www.intelrealsense.com/how-to-getting-imu-data-from-d435i-and-t265/
HDiet
Hello MartyG
thanks for your answer. So I think it´s possible to use is. From acceleration sensors I know that they are drifting away, which leads to errors in position and velocity. Does the T265 also have this issue?
MartyG
The T265 can use 'wheel odometry' to increase its accuracy.
https://github.com/IntelRealSense/librealsense/blob/master/doc/t265.md#what-is-wheel-odometry-and-how-does-it-help-t265-navigate
Edit: a user on the RealSense GitHub posted their own test data about drift.
https://github.com/IntelRealSense/librealsense/issues/4412#issuecomment-511059890
