Items with no label
3341 Discussions
lfsr code for bit swapping between bits if lsb is 0 in verilog in a 8 bit code
SSRIV16
I tried writing the code but desired ouput is not generated ,please help me out as early as possible,i need to submit my assignment before 25 feb. lfsr code to swapping bits B7 and B6 when lsb i.e B0 is O here in this generated code output coming is wrong ,please help me out as early as possible designed various block as well as connection ,earlier the error was regarding output and inout ports but i resolved that
module R_DFF( input clk, input d, output q ); wire g2,r,s,g1; reg b; initial b= 1'b1; PG d2(clk,b,1'b0,d,g1,q,r,g2); always@(*) begin b = r; end endmodule   module PG( input a, input b, input c, input d, output reg p, output reg q, output reg r, output reg s );   always@(*) begin p = a; q = (((~a)*b)^(a*d)); r = (((~a)*b)^(a*d)^c); s = (b^d); end endmodule           module DFG( input a, input b, input c, output reg p, output reg q, output reg r ); initial assign p=a; initial assign q=a^b; initial assign r= a^c; endmodule       module FG( input a, input b, output reg p, output reg q ); initial begin p = a; q = a^b; end endmodule       module R_bs_lfsr8( input reg clk, output wire [0:7]q, output reg [0:7]OUT );   reg d; reg sel;     wire [0:7]q1; wire [0:7]g1; wire [0:2]g2; wire [0:2]x1; wire [0:2]x2; initial d=1'b1; assign g1=8'b10000001; R_DFF f1(clk,d,q1[0]); FG m1(q1[0],1'b0,q[0],g1[0]);   R_DFF f2(clk,g1[0],q1[1]); FG m2(q1[1],1'b0,q[1],g1[1]);   R_DFF f3(clk,g1[1],q1[2]); FG m3(q1[2],1'b0,q[2],g1[2]);   R_DFF f4(clk,g1[2],q1[3]); DFG m4(q1[3],1'b0,1'b0,q[3],g1[3],g2[0]);   R_DFF f5(clk,g1[3],q1[4]); DFG m5(q1[4],1'b0,1'b0,q[4],g1[4],g2[1]);   R_DFF f6(clk,g1[4],q1[5]); DFG m6(q1[5],1'b0,1'b0,q[5],g1[5],g2[2]);   R_DFF f7(clk,g1[5],q1[6]); FG m7(q1[6],1'b0,q[6],g1[6]);   R_DFF f8(clk,g1[6],q1[7]); FG m8(q1[7],1'b0,q[7],g1[7]);     FG m9(g1[7],g2[2],x1[0],x2[0]); FG m10(x2[0],g2[1],x1[1],x2[1]); FG m11(x2[1],g2[0],x1[2],x2[2]); assign g1 = q; always@(negedge clk) begin d <= x2[2]; sel= q[7];     begin if(sel == 1'b0) begin OUT[0]<= q[1]; OUT[1]<= q[0]; OUT[2]<= q[3]; OUT[3]<= q[2]; OUT[4]<= q[5]; OUT[5]<= q[4]; OUT[6]<= q[6]; OUT[7]<= q[7]; end else if(sel == 1'b1) begin OUT[0]<= q[0]; OUT[1]<= q[1]; OUT[2]<= q[2]; OUT[3]<= q[3]; OUT[4]<= q[4]; OUT[5]<= q[5]; OUT[6]<= q[6]; OUT[7]<= q[7]; end   end end       endmodule             module R_bs_lfsr8_tb;   reg clk; wire [0:7]q; wire [0:7]out;     R_bs_lfsr8 lf(clk,q,out); initial begin   clk=0; forever #10 clk=~clk; end initial begin force lf.q=8'b10000001; #91; release lf.q; end endmodule
