Items with no label
3338 Discussions
libopencv-dev broke with RealSense Samples Install
eepp
I broke libopencv-dev during my install of RealSense Samples for the D200. I wanted to install realsense_ros_camera. My goal was to use it with OpenCL Caffe, which at the time was working with my laptop's built in web cam. It appears that I should not have attempted this and should have moved on to newer RealSense camera instead. I attempted to roll back by uninstalling RealSense Samples but have been unable to recover libopencv-dev. Furthermore, I cannot install RZ300 drivers until libopencv-dev is fixed.
Apologies: I'm afraid that my knowledge of Ubuntu allows me to get into trouble but not always out of it. Details follow.
  • Ubuntu: 16.04
  • ROS: Kinetic
  • D200 (I will upgrade to a RZ300 after I fix libopencv-dev)
  • Recent Dell Laptop
I believe I broke OpenCL Caffe and other applications when I did this during RealSense Samples install.
sudo apt install -y librealsense-object-recognition-dev librealsense-persontracking-dev librealsense-slam-dev libopencv-dev
This is what I discovered about my install.
$ aptitude search librealsense-object-recognition-dev
u librealsense-object-recognition - Intel(R) RealSense(tm) Object Recognition
$ aptitude search librealsense-persontracking-dev
u librealsense-persontracking-dev - Development files for Intel RealSense Pers
$ aptitude search librealsense-slam-dev
u librealsense-slam-dev - Development files for Intel RealSense SLAM
$ aptitude search libopencv-dev
BB libopencv-dev - development files for opencv
p libopencv-dev:i386 - development files for opencv
I attempted to back out by removing all the packages I installed above with:
sudo apt-get remove
Then I reinstalled libopencv-dev. It failed when it tried to unpack libopencv3.1-java.
sudo apt-get install libopencv-dev
Unpacking libopencv3.1-java (3.1.0+dfsg-1~realsense4.18) ...
dpkg: error processing archive /var/cache/apt/archives/libopencv3.1-java_3.1.0+dfsg-1~realsense4.18_all.deb (--unpack):
trying to overwrite '/usr/share/java/opencv.jar', which is also in package libopencv2.4-java 2.4.9.1+dfsg-1.5ubuntu1
In retrospect it appears to be trying to install libopencv-dev 3.1 over 2.4.9 and couldn't. I don't fully understand what the problem is and did a lot of unwise things while I was trying to figure it out. I am no longer sure what my opencv status is. I understand that ROS has problems with version 3. On my other Ubuntu box it has ros-kinetic-opencv3, libopencv-dev, and libopencv2.4-java installed. I think I want to get back to that state and don't know how.
This is my current status when I attempt to install libopencv-dev.
-- BEFORE libopencv-dev INSTALL
$ aptitude search libopencv2.4-java
p libopencv2.4-java - Java bindings for the computer vision libr
~$ aptitude search libopencv3.1-java
p libopencv3.1-java - Java bindings for the computer vision libr
~$ aptitude search libopencv-dev
p libopencv-dev - development files for opencv
<s...
MartyG
Do you mean you have an F200 camera, please? the D naming convention was only started with the current generation of RealSense cameras.
A process that has worked for some people when failing to reinstall OpenCV after an uninstall is:
1. Uninstall OpenCV 3.3.1
2. try
$ sudo apt-get -f install
3. Use this instruction:
$ apt-get purge libhighgui-dev
eepp
Thanks! I'll try this.
The camera is actually a R200. It is part of a TurtleBot3 kit. See http://emanual.robotis.com/docs/en/platform/turtlebot3/specifications/# hardware-specifications TurtleBot3 . Apologies.
eepp
This didn't fix the problem and broke viewing from my built-in usb cam. This is what I did.
2005 sudo apt-get remove ros-kinetic-opencv3
2006 aptitude search opencv | grep ^i
2007 sudo apt-get -f install
2008 aptitude search libhighgui-dev
2010 sudo apt-get purge libhighgui-dev
2011 sudo apt-get install ros-kinetic-opencv3
2014 sudo apt-get install libopencv-dev
This is the status. I don't know what the "B" means in the context of "iB".
~$ aptitude search ros-kinetic-opencv3
i ros-kinetic-opencv3 - OpenCV 3.x
p ros-kinetic-opencv3:i386 - OpenCV 3.x
iB libopencv-dev - development files for opencv
iBA libopencv3.1-java - Java bindings for the computer vision libr
~$ aptitude search libopencv2.4-java
Notice that libopencv-dev and libopencv3.1-java did not get installed correctly. I was hoping it would install libopencv2.4-java instead because that is what my other Ubuntu system has installed on it.
Do you need more detail?
MartyG
Thanks for the extra information. I'm very sorry that your situation has not improved.
I am not an expert on the workings of Ubuntu, unfortunately as my main experience is with Windows. If your Ubuntu installation has got in as much of a tangle as you say then it may be easier just to wipe and reinstall Ubuntu, and then OpenCV and Librealsense, from the beginning.
Alternatively, you could post a help request over on the RealSense GitHub, where the RealSense developers and engineers reside. To open a new case, click on the 'New issue' button the link below. Good luck!
https://github.com/IntelRealSense/librealsense/issues Issues · IntelRealSense/librealsense · GitHub
