Items with no label
3338 Discussions
optimising Euclid depth cam to prioritize close-range objects
kfind
I have found that the Euclid's default settings mean that it has trouble seeing small-ish objects (12 x 12 cm, 4cm high) at less than 1m. By trouble, I mean the data is missing/black in the depth image where the object should be. Only when the camera is moved back to about 1 or 1.1m away, does the object finally appear in the depth image data.
Is this something that changing the depth gain or providing an ambient IR flood light might help with? I played with the depth and exposure parameters of the R200 way back, and it did help with similar circumstances, just not sure if the Euclid's camera technology/settings work in the same way, or if someone else has found a good combination of these parameters for their own projects.
Hi KFindlater,
Thanks for your interest in the Intel Euclid platform.
I think you can try lowering the depth gain (in ROS is r200_lr_gain) to 100, it improves the camera's performance, also try to run the dynamic calibration guide: https://click.intel.com/media/productid2100_10052017/dynamic_calibration_guide.pdf https://click.intel.com/media/productid2100_10052017/dynamic_calibration_guide.pdf.
Let us know if it helps.
-Yermi A.
kfind
Hello Yermi,
Thanks for that information. Is there a way with the librealsense running on the Euclid with the C++ API (not involving ROS at all) to read and write the gain?
Please take a look at the following information that defines general configuration controls in librealsense: https://github.com/IntelRealSense/librealsense/blob/master/include/librealsense/rs.hpp https://github.com/IntelRealSense/librealsense/blob/master/include/librealsense/rs.hpp.
Hope this information helps.
-Yermi A.
kfind
So from my testing, I was able to get good quality depth data as close as 38-40cm away, by setting the gain to 100 and by using the 320x240 pixel, 60fps depth stream.
GSR
How and where do you change the resolution?
To change the resolution you have to change the color_height and color_width parameters in this launch https://github.com/IntelEuclid/realsense_camera/blob/master/launch/lr200m_nodelet_default.launch https://github.com/IntelEuclid/realsense_camera/blob/master/launch/lr200m_nodelet_default.launch. The file can be edited directly or using the Euclid browser interface. The easiest way to do this using the Euclid browser interface is described in the attached document.
kfind
Using the software API (in my case, Librealsense in linux) you enable/start the stream either by specifying all of the settings manually, or what I do is choose rs::preset::highest_framerateand it automatically goes down to 320x240 resolution and 60 fps.
for example a line in my C++ code is:
dev.enable_stream(rs::stream::depth, rs::preset::highest_framerate);
