Items with no label
3338 Discussions
problem compiling librealsense-2.10.0 for D415 realsense.
Eyoon1
I'm having problems compiling librealsense-2.10.0. I keep get the following error:
/usr/bin/ld: /usr/local/lib/libglfw3.a(vulkan.c.o): undefined reference to symbol 'dlsym@@GLIBC_2.17'
//lib/aarch64-linux-gnu/libdl.so.2: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
examples/software-device/CMakeFiles/rs-software-device.dir/build.make:98: recipe for target 'examples/software-device/rs-software-device' failed
make[2]: *** [examples/software-device/rs-software-device] Error 1
CMakeFiles/Makefile2:260: recipe for target 'examples/software-device/CMakeFiles/rs-software-device.dir/all' failed
make[1]: *** [examples/software-device/CMakeFiles/rs-software-device.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
I've previously had no problems compiling in the nvidia tegra TX2 shipped . It started problems after upgrading L4T28.2 version. .
Any suggestions would be greatly appreciated!
MartyG
This is a tricky problem. I find that when a list of errors occurs, it's good practice to focus on the first one in the list, since once the first error occurs, it can create a cascade of errors that are only occurring because of that first error and no longer appear once that initial error is cleared.
The first line mentions GLIBC_2.17. My research indicates that some people have had problems with LIBC after doing an upgrade. They fixed their problem by doing an update of LIBC to ensure that they had the latest version of it.
sudo apt-get update
sudo apt-get install libc6
Eyoon1
The problem has been solved by upgrading from L4T28.2 to JetPack-L4T-3.2-linux-x64_b157.run.
Please refer to https://github.com/IntelRealSense/librealsense/blob/development/doc/installation.md# video4linux-backend-preparation librealsense/installation.md at development · IntelRealSense/librealsense · GitHub .
If you have a problem with libudev.h error at the build time, execute the following command.
$sudo apt-get install libudev-dev
best regards
Ericyoon.
MartyG
Thanks so much for the feedback about how you solved your problem!
