Items with no label
3338 Discussions
pyntcloud?anky.plot(mesh=True, backend="threejs")
tguan
i tried the examples below, everything is ok ,but why doesn't it show points images such as
https://github.com/daavoo/pyntcloud/tree/master/examples pyntcloud/examples at master · daavoo/pyntcloud · GitHub
the note says:
Note that we are passing the argument backend="threejs" because mesh visualziation is not currently supported with the default backend.
Because of this, the visualization might don't work in some enviroments (i.e. binder). We are working to add support to mesh plotting with the default backend as soon as possible in order to fix these issues.
i want to know wahere i can find the .plot Parameter usage and display thr points
MartyG
Have you seen the anky tutorial article about getting the points? In the tutorial, the creator of Pyntcloud says that he uses the Plot() function to visualize the mesh and point cloud of the ankylosaurus.
https://medium.com/@daviddelaiglesiacastro/3d-point-cloud-generation-from-3d-triangular-mesh-bbb602ecf238 https://medium.com/@daviddelaiglesiacastro/3d-point-cloud-generation-from-3d-triangular-mesh-bbb602ecf238
tguan
I am so sorry that I cannot open the website but thank you for your reply.
i have already try all the examples below,any thing is ok,but the .plot function seems to not work,i cannot visualize the points.
i wonder wherther the pyntcloud can work only on specific platform or i have some defalts that i donnot realize.
it has troubled me a lot.
tguan
ok,I realized that it can visualize in jupyter ,so do you know more about pointcloud processing methods,if you know ,please recommend it to me ,because i want to show the points in windows.
thank you all the way ,maybe the question is out of your range.
thank you
MartyG
RealSense SDK 2.0 has a C++ point cloud tutorial for displaying a point cloud in a window.
https://github.com/IntelRealSense/librealsense/tree/master/examples/pointcloud librealsense/examples/pointcloud at master · IntelRealSense/librealsense · GitHub
