Items with no label
3338 Discusiones
"Intel® RealSense™ Depth Camera D435" or "Intel® RealSense™ Robotic Development Kit"
ic
Principiante
1.922 Vistas
We are a small company, we are looking to get/buy/test code/device that will measure the depth of 3D holes in objects. We are taking 2D images of these objects using light microscope and we want to measure/estimate with very small error, the depth of these 3D holes.
It borders to 3D reconstruction, but we need precise measurements. Maybe attaching software/device to the microscop? Can this product "Intel® RealSense™ Depth Camera D435" or "Intel® RealSense™ Robotic Development Kit" do this and can we get in touch with development team? We have 2 months(included testing) to integrate the device/code into our system
Can you help or guide us in a better direction?
Many many thanks,
Kind regards,
icc4
https://click.intel.com/realsense.html https://click.intel.com/realsense.html
0 kudos
1 Responder
MartyG
Colaborador Distinguido III
787 Vistas
If you are looking to develop a commercial product, the R200 in the Robotic Development Kit may not be the best choice. This is because it is a retired product line and so it is uncertain how much longer it will be available if you need multi-year supply of it. It is also the oldest of the currently available RealSense models, so its tech is out of date.
Furthermore, the cased USB R200 used in the Robotic Development Kit is not suitable for commercial purposes, as it has a limited-duration warranty. It is preferable to integrate a caseless Module Kit circuit board version of the camera into your product. The easiest way to obtain the module version of the R200 is in the Intel Aero Vision Accessory Kit for drones. Again though, it is unknown how long this product will continue to be available to purchase.
https://click.intel.com/intel-aero-platform-for-uavs-vision-accessory-kit.html Intel® Aero Platform for UAVs Vision Accessory Kit
Also, the accuracy on the old RealSense cameras averages +- 5%, whereas the 400 Series cameras average 1% or less. At close range though, you may need to alter the scaling factor of the camera to get the best results.
For accuracy, latest vision technology and long-term future proofing, and image quality, the 400 Series Camera may be the best choice. It is planned that in 2020, a next-generation D600 will be introduced that provides an easy upgrade path from the D415 / D435, meaning that it should be straightforward to upgrade your product.
If the holes that you are going to be scanning are in a fixed position, the D415 may suit your needs, as it excels at scanning static objects. It is also currently the easiest 400 Series camera to obtain, as the D435 ordering process is currently backlogged due to short supplies, whilst the D415 is available to order today
If you anticipate that the holes or the camera will be moving, the D435 is the appropriate choice. Due to the aforementioned short supplies, you could start prototyping with D415 now and switch to a D435 when the supply situation improves.
For the final version of your product, both the D415 and D435 have caseless Module Kit circuit board versions with varying configurations denoted by product numbers (e.g D400, D410, and D415 for the D415, and D420 and D430 for the D435).
A further configuration option that may be available to you may be to use a custom RGB sensor other than the default one used by the 400 Series, so that you can get a more industrial-level quality of sensing than the default sensor can provide.. This can be attached via a custom made 50-pin cable to the Vision Processor component of the camera's circuit board.
The data sheet document linked to below contains the technical details of the 400 Series camera and Module Kit range.
https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Intel-RealSense-D400-Series-Datasheet.pdf https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Intel-RealSen
Responder
